Any links to a suitable product?
Parking heater (UK)
Parking heater (UK)
Has anyone installed an aftermarket parking heater in their RS? Winter is approaching and I leave rather early and it would be kinder to the neighbours if my car was defrosted prior to my departure without the engine running for too long
aerospace100
- 1st Gear
Re: Parking heater (UK)
Looking at the Audi website it appears the auxiliary heater is available for Q2 and A3 models only. However, further searching on Google suggests it could be done from 12V supply on a timer - unofficial part.hdpete wrote: ↑Sun Sep 09, 2018 8:27 amHas anyone installed an aftermarket parking heater in their RS? Winter is approaching and I leave rather early and it would be kinder to the neighbours if my car was defrosted prior to my departure without the engine running for too long![]()
https://shops.audi.com/en_GB/web/zubeho ... ary-heater
2017 C7 RS6 PE Nardo
2015 Porsche 958 Carmine Red
2012 Porsche 958 Black
2009 A5 Misano
2000 Grand Cherokee Limited V8
1992 RS1800
1998 Escort GTi
1993 Astra GSI Red Top
2009 A5 Misano
1992 RS1800
1998 Escort GTi
Kufatec do a kit but it says not Suitable for RS6
Love this idea!
No one does an after market product that you can just chuck in the boot to heat up inside the car?
Years ago I had a 12v heater in the boot, I had the car reversed up to the garage with a power supply on a timer in the garage, it worked like a dream
Did you ever drive off before remembering to disconnect it?
If it's just a 12v fan heater you want then there are loads about. See https://www.carparts4less.co.uk/cp4l/p/ ... eIEALw_wcB for eample.
But if you are going to have to plug in an external charger, why not just buy a mains fan heater and plug that in??
I didn't want to have a 240v lead and plug outside, the 12v didn't matter if it got wet or damp.
You can keep both ends of an extension lead dry by simply keeping the socket inside the car, and the plug in the garage. Then all you have is a cable outside.
Plug in electrical heaters (mains) are common in Scandinavia, as are block heaters etc - all mains powered.
Of course, it does slightly up the ante if you drive off without unplugging!
