Minimum brake Disc thickness
LeeRS6
Post by LeeRS6 » Fri Sep 07, 2018 3:44 pm
I remember reading it here but can't find the post, can someone please tell me the minimum disc thickness for both front and rear discs.
skirs6
Re: Minimum brake Disc thickness
Post by skirs6 » Fri Sep 07, 2018 9:09 pm
Front 👍
skirs6
Post by skirs6 » Sat Sep 08, 2018 4:45 pm
That can’t actually be correct or may mean something else as just measured brand new and they are only 36mm ???
EmilA
Post by EmilA » Sat Sep 08, 2018 4:57 pm
Nope that’s prob about right tbh..
dasquade
Post by dasquade » Sat Sep 08, 2018 5:57 pm
Euhm unless i read it wrong: new 36mm and like it says on the disks min thickness: 34.4mm (i know, that would mean they are worn if only 0.3mm is gone, sounds not right).
If i'm not wrong, the inner and outer not fully drilled holes correspond with the min thickness. Meaning if you almost level with those holes = replace disks.
Post by MikeFish » Sat Sep 08, 2018 7:07 pm
1.6mm wear and they need replacing. Sounds about right. The B7 had 2mm wear.
LeeRS6
Post by LeeRS6 » Sun Sep 09, 2018 11:39 pm
Thanks I’ll have a look on the rear ones to see what they are
nowva
Post by nowva » Mon Jun 08, 2020 8:38 pm
I’m looking at buying from the main dealer I said about the wear marks but they say they are not worn out yet the current discs are level with the marks you can only just see the faint outline. Can’t even feel the marks with my finger. They said they replace anything that is more than 25% worn that’s the requirement for approved used Audi in the uk. Can anyone confirm these are wear marks before I go back to dealer?
noidea
Post by noidea » Mon Jun 08, 2020 9:04 pm
You would need to measure them, but if you can't see the dimple I would say they are worn out. How many miles has the car done?
Sent from my Pixel 2 XL using Tapatalk
nowva
Post by nowva » Mon Jun 08, 2020 9:58 pm
its done just less than 30k miles
noidea
Post by noidea » Mon Jun 08, 2020 10:34 pm
They maybe the originals, if they are they need changing. Get them to measure them. Have you checked the history on the car, are there any invoices for the service work?
