If anything untoward happens to the discs, can they be refinished, or is it new discs end of?graeme4130 wrote:I think I did a couple of sets of pads in 56k
Right. It’s quite a dilemma, if talking £6000 to replace if anything does happen, not sure I could swallow that! I’m guessing Audi won’t offer any good will either...doodlebug wrote:They are brittle, so if you get a stone caught or you break a bit off they are done. They don’t generally get surface damage that isn’t catastrophic.
You can pick up C7 discs for 2-3k on ebay. Pretty sure you could get away with only replacing one discs if they had a catastrophic failure.vestax32 wrote: ↑Sat Sep 08, 2018 3:19 pmRight. It’s quite a dilemma, if talking £6000 to replace if anything does happen, not sure I could swallow that! I’m guessing Audi won’t offer any good will either...doodlebug wrote:They are brittle, so if you get a stone caught or you break a bit off they are done. They don’t generally get surface damage that isn’t catastrophic.
I'm pretty sure they can't be skimmed as the difference between new and worn out is microns rather than mm - They have dots on them as wear indicators and when new, the dots are barely recessed as is
Users browsing this forum: No registered users and 23 guests
