Now onto the last part of 'body II', Clutch A
Unclip the oil collector
Next up is real tricky sod, you need to place a small screwdriver up in between those outer notches and the planetary gears - there is a circlip on the inner edge holding the planetary gear assembly in place, you need to lever this clip out of its seat in the four points around the gears. You will need a torch to see it and a lot of patience
If we now flipthis upside down
That's the sod there, if you want to replace this one its ZF code 0730.513.825, the book recommends you do so
You can also clearly see the four inner recessed notches you need to get the driver onto to pry this clip off (easy to see now, not so easy with this in situ!)
Now lift out the sun gear
Unclip and inspect the needle bearing
