Window issue
Mark-RS
Window issue
Post by Mark-RS » Fri Aug 24, 2018 10:17 pm
When I bought the car I bought it with an issue with the drivers window. It was apparently sticky and would go a little way up and then go back down again.
I found this only to happen when the window was opened a little bit, if the window was wound most of the way down, it would roll right back up again with no issues.....
Until today..... :boohoo:
Wound all the way up and then I heard a crack ! Wound it back down just a fraction maybe a couple of inches and it won't go back up again. I have managed to wedge the window up and it appears to be staying.
Can anyone tell me what part I am likely to need without me stripping it all down first ?
My puddle light on the drivers side ha never worked either so it would make sense to sort that also, which I believe is the lock mechanism ?
Any advice is appreciated as always.
Oh and if anyone wants to give me a loan, it would be very welcome !" Bought the car in January and have spent nearly £4k on it until now, and the TC is knackered also. Stupid ass car, shoulda bought something else :<beep>_you:
EireRS6
Re: Window issue
Post by EireRS6 » Fri Aug 24, 2018 10:23 pm
Jeez, I thought I had it bad spending half that in the same time!
Sorry, can't help with the window but have the same puddle light issue which I was told is the lock mechanism.
Sent from my SM-A520F using Tapatalk
Re: Window issue
Post by Shoppinit » Sat Aug 25, 2018 7:23 am
Sounds like the window regulator has snapped. No biggy. ECP might have them.
srichards
Re: Window issue
Post by srichards » Sat Aug 25, 2018 9:21 am
The first year is always the worst. You are fixing things the previous owner was ignoring and you have all the things that were about to break to fail as well!
https://www.amazon.co.uk/RegulatorFix-A ... B00BT1GQCU - These the right ones? If so I'm going to get a set as well to ensure mine never breaks...
Re: Window issue
Post by Shoppinit » Sat Aug 25, 2018 10:39 am
Those break often so worth having a set. However, in this case it sounds like the regulator itself has broken. You'll need to open it up to have a look. I've had this on a Golf. You need to change the whole gubbins.
https://www.mister-auto.co.uk/front-win ... 00003.html
I'd get a Valeo one. You can get much cheaper on eBay, but given the faff of getting the window out, I wouldn't want to do it twice.
/Also, change the door lock while you're at it. If you're handy you might be able to replace just the microswitch that has failed.
Mɐʇʇ
Re: Window issue
Post by Mɐʇʇ » Sat Aug 25, 2018 12:13 pm
This for sure. I'd happily get in mine and drive it 10k straight up, and I'd be confident it would need nothing more than routine servicing.
R5XVB
Re: Window issue
Post by R5XVB » Sat Aug 25, 2018 12:30 pm
Yep, be sure to get a quality regulator kit and not the cheapest one because I can tell you from experience it’s a bitch. Expect to pay £30 aftermarket and about £90 OEM. It’s a pain in the ass to fit compared to most others due to a metal plate in the way and unless someone else knows a method the upper part of the door needs removed, job for under a roof in the dry.
Mɐʇʇ
Re: Window issue
Post by Mɐʇʇ » Sat Aug 25, 2018 12:40 pm
Fortunately the upper door is easy. Looks a pain in the neck, but not too bad at all. And it's generic A6, not RS6, so easy parts
Mark-RS
Re: Window issue
Post by Mark-RS » Sat Aug 25, 2018 1:29 pm
Really appreciate the advice guys, makes carrying the cost a little easier !
Door lock generic also ?
Mɐʇʇ
Re: Window issue
Post by Mɐʇʇ » Sun Aug 26, 2018 10:13 am
Yeah. Go OEM on the lock. More ££ but you'll only to replace it the once.
bilko1
Re: Window issue
Post by bilko1 » Sun Aug 26, 2018 11:10 am
If you have dual pain glass you will have to get it from Audi / TPS as after market don't seen to do the regulator for dual pain. If memory serves me you will need a few rivets as well.
Mark-RS
Re: Window issue
Post by Mark-RS » Sun Aug 26, 2018 12:21 pm
Nope, just single pain glass, so I guess lucky on that front :-)
Weiß-sechs
Re: Window issue
Post by Weiß-sechs » Tue Aug 28, 2018 3:26 pm
I'm in pain reading about your pane....
Mɐʇʇ
Re: Window issue
Post by Mɐʇʇ » Tue Aug 28, 2018 3:41 pm
I knew someone would do it.... :D
bilko1
Re: Window issue
Post by bilko1 » Wed Aug 29, 2018 11:17 am
I had pain on the mind as I'm currently off work with a fractured ankle. That's my excuse and I'm sticking to it :)
Users browsing this forum: No registered users and 168 guests
