DIY to replace both exhaust downpipe flexi’s
Mɐʇʇ
Re: DIY to replace both exhaust downpipe flexi’s
Post by Mɐʇʇ » Tue Jul 24, 2018 11:27 pm
I think so, yeah. But if you buy a 63mm flexi, the flexi is a lot smaller than 63mm which'll cause a restriction (bad on a turbo motor), which is why I used a 76mm flexi and then welded a reducer on to bring the pipe size down to 63.
skyegtb
Post by skyegtb » Wed Jul 25, 2018 5:31 pm
I've just re-instated the pictures hopefully they can be seen again.
2003 RS6 MTM 568
mavada
Post by mavada » Thu Jul 26, 2018 12:14 pm
Yes, thanks alot :D
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
EireRS6
Post by EireRS6 » Tue Aug 07, 2018 4:47 pm
Skyegtb, do you have part numbers of the flexis you used?
Sent from my SM-A520F using Tapatalk
skyegtb
Post by skyegtb » Tue Aug 07, 2018 6:34 pm
2003 RS6 MTM 568
EireRS6
Post by EireRS6 » Tue Aug 07, 2018 11:37 pm
Cheers. So did that ID of 60.3mm fit over the existing pipe??
skyegtb
Post by skyegtb » Wed Aug 08, 2018 8:30 am
Yes, it was a perfect fit, but remember that I have Milltek downpipes not OEM
2003 RS6 MTM 568
EireRS6
Post by EireRS6 » Wed Aug 08, 2018 9:04 am
Ah yes, sorry. Forgot that!
skyegtb
Post by skyegtb » Wed Aug 08, 2018 9:41 am
The best advice I can give, if you were attempting this, would be to completely remove the old flexis, then accurately measure everything up - all lengths, diameters etc, then simply head over to eBay and you will find the correct flexis sold by one of the sellers there. 0.3mm is the standard oversize to allow fitting the new flexi over the existing pipe, but if that is not correct as per your measurements a lot of the companies will custom manufacture you a flexi very often for no extra cost.
2003 RS6 MTM 568
Mɐʇʇ
Post by Mɐʇʇ » Wed Aug 08, 2018 11:56 am
And, be really mindful that exhaust back pressure is a killer on a turbo motor. The 63mm flexis I got were a restriction, hence I used 76mm ones and sleeved the tubes down.
Post by Shoppinit » Wed Aug 08, 2018 12:16 pm
Good thinking.
skyegtb
Post by skyegtb » Wed Aug 08, 2018 12:31 pm
The flexis I fitted were (internal diameter) the same as the Milltek originals. I didn't like the way they were fitted and the big step down to 60mm on the pipes, but at the time I was just happy to put it back as it originally was. I did wonder why they stepped it down so much, perhaps there were space issues?
2003 RS6 MTM 568
EireRS6
Post by EireRS6 » Wed Aug 08, 2018 5:34 pm
skyegtb wrote:The best advice I can give, if you were attempting this, would be to completely remove the old flexis, then accurately measure everything up - all lengths, diameters etc, then simply head over to eBay and you will find the correct flexis sold by one of the sellers there. 0.3mm is the standard oversize to allow fitting the new flexi over the existing pipe, but if that is not correct as per your measurements a lot of the companies will custom manufacture you a flexi very often for no extra cost.
Unfortunately I don't have the luxury of being able to strip everything down and measure the necessary sizes before ordering. Ideally would need the new flexis to replace the old ones in one visit.
Users browsing this forum: 111marc111 and 79 guests
