Help!! Changing Analog to Digital Cluster !
Hi all ! I have a 99.5 facelifted S4, but with the analog clock, and I just found a cluster from a newer S4 with the new logo and digital clock, can I put this cluster in my car ?
tartan_rob
RE: Help!! Changing Analog to Digital Cluster !
Not sure, but I think the newer car runs CAN Gateway, whcih means no. If you can do it, let me know. I'll do the same. Perhaps someone with more knowledge can comment...?
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
I assume you mean the digital clock from the 2000/2001 facelift B5 S4. I'm sure the B5 doesn't run CAN, so I reckon it would work... but don't hold me to that one.
2000 Nogaro S4 Saloon
Yes the B5 does have CAN. Note that there is not CAN or No-CAN, there are are several degrees of CAN. The B5 facelift has 3 CAN buses with different speeds/protocols according to what they are used for. The B6 and B7 have more use of CAN (and maybe more buses, I don't know).
However Audi made lots of things backward compatible, so the new cluster will have CAN and the old bus system (CLK & DATA).
So yes you can make it work, but I don't know how much effort is required to do so...
2001 Silver S4 Avant
Users browsing this forum: No registered users and 44 guests
