Fault code P2004
standard rs4
Fault code P2004
Post by standard rs4 » Mon Aug 06, 2018 11:23 pm
Hi all I have got a fault code coming up P2004 intake manifold runner control stuck open bank 1.
Is there any chance that if I used wynns dip3 intake cleaner that it would sort out the problem ?
If not what can be done to sort it out apart from the costly route of decarbon and deflap ?
As my name on here says standard rs4 so I do want to try to keep it that way as it is a very straight car.
standard rs4
Re: Fault code P2004
Post by standard rs4 » Mon Aug 06, 2018 11:42 pm
Sorry I should have also said that it is a B7 done 70k.
As far as I am aware always used the correct fuel, it has for sure for the last 2 years that I have owned it.
standard rs4
Post by standard rs4 » Thu Aug 16, 2018 2:50 pm
Well I am pleased to say good news, it was a solenoid valve happy days :beerchug:
GaryA
Post by GaryA » Fri Aug 17, 2018 6:59 am
Result in fixing. Is this all you've had to address in 2 years ?
standard rs4
Post by standard rs4 » Fri Aug 17, 2018 8:40 am
Hi Gary no I wish it was but it has been a very good car. I have had to replace the front discs and pads what I knew about when I bought it, and then a oil leak from a hose going to the oil cooler what then led to both hoses and a oil cooler last year and a set of tyres this year, so I am pretty happy with it. It has been very well looked after only one previous owner from new.
Return to “General Car Chat”
Users browsing this forum: No registered users and 133 guests
