Left indicator warning light questions
4.2 V8 32v FSI - 444 bhp
jangol
Post by jangol » Wed Aug 01, 2018 6:53 am
Morning,
The left indicator warning light is showing up the dash, it’s appears the light side wing mirror indicator doesn’t light up/flash through the whole light, (just both ends)
Is that a bulb issue (if you can change them) or a wiring issue, how would I investigate you can see some mist in the picture
johnnydog
Re: Left indicator warning light questions
Post by johnnydog » Sat Aug 04, 2018 11:58 pm
I doubt there will be a bulb to change - it most likely will need the mirror indicator repeater light unit replacing. It's not difficult to do, but will need the mirror glass popping off to gain access
I'd ring your local Audi dealers parts department- I'm sure they will be able to give you the info as to whether it is a bulb or a complete repeater unit that needs replacing.
jangol
Post by jangol » Sun Aug 05, 2018 10:22 pm
Thanks,
Will give that a go!
jangol
Post by jangol » Mon Aug 06, 2018 9:41 pm
Ordered a replacement repeater from the steelers... will fit at the weekend
Surrey Sam
Post by Surrey Sam » Tue Aug 07, 2018 10:20 am
Check the old one over and see if it's damaged, might have been done when fitting the aftermarket carbon covers?
jangol
Post by jangol » Tue Sep 04, 2018 9:20 pm
New indicator sorted it
p’s complete carbon unit not just a cover
Users browsing this forum: No registered users and 23 guests
