knocking suspension and leak rear drivers side?
sweatysRS
Post by sweatysRS » Mon Jul 02, 2018 6:27 pm
So got quite a lot of knocking over bumps front end particularly n/s. Lower arms? But also have a small leak rear drivers side. Any ideas?
RS4LAD
Re: knocking suspension and leak rear drivers side?
Post by RS4LAD » Mon Jul 02, 2018 7:36 pm
May be DRC they go together on opposite corners
johnnydog
Post by johnnydog » Sun Jul 08, 2018 4:55 pm
Definately go with the front shocks of the DRC being suspect. A leak in the system at the rear as you describe will damage the system if not fixed immediately due to the low pressure. Was a common issue when the cars were younger and Audi extended the warranty on these components for several years, but obviously not now!!
neil_f
Post by neil_f » Sun Jul 08, 2018 7:01 pm
I'll be removing drc dampers from my car in just under two weeks time if your looking for replacment ones. PM me if you need them
jon_273
Post by jon_273 » Sun Jul 08, 2018 7:43 pm
I had a slight knock and after I got the DRC recharged (it was down to 12 bar) it stopped.
sweatysRS
Post by sweatysRS » Tue Jul 10, 2018 6:15 pm
Hi thanks all. How is it recharged and what should the pressure be? Cheers
bennn
Post by bennn » Thu Jul 12, 2018 8:51 am
How long did it last? Surely if it needed a recharge it must be leaking from somewhere?
jon_273
Post by jon_273 » Fri Jul 13, 2018 5:07 pm
It should be 16 bar when fully charged.
I had it done in april and it's still ok so far. Time will tell. I think it just seeps past the shock absorber seals slowly over years and years. I think if more people did maintenance on it there would be many more RS4's still with DRC.
Fandango
Post by Fandango » Mon Jul 16, 2018 2:06 pm
Can help with parts if need be have rwo brand new(in box) front shocks for RS4 avant 2007 for slae - plus all the old shocks and pipes from the repair (for a nominal amount) if they can help!
Let me kbow im on the site as Fandango and Alicz77 (dont ask early issues when joining the forum)
sweatysRS
Post by sweatysRS » Tue Jul 17, 2018 9:22 pm
Thanks all. Cheers Fandango. The car is booked in to Audi in the morning for re charge £299 all in. Will let you know if all ok.
sweatysRS
Post by sweatysRS » Thu Jul 19, 2018 4:51 pm
F*c**n spiders! Spoke to Audi today.....front 2 damper pipes got splits in. Got a nice bill of £1194 to fit 2 front damper pipes and do a recharge of the drc! Hope that's it!? :audibash: :drink:
neil_f
Post by neil_f » Thu Jul 19, 2018 8:41 pm
Presuming it was just the flexi pipes that connect onto the damper? If so that seems a mental amount to charge although I know the price of the hoses is ridiculous. Think I'd have told them where to go and ditched the drc.
sweatysRS
Post by sweatysRS » Sun Jul 22, 2018 9:39 pm
Cost £980 in the end. All good and drives as it should again.
markieparkie
Post by markieparkie » Wed Aug 08, 2018 2:32 pm
Hi all,
What's the cover they provide for this situation now? More then the usual 3 years? I have a 2012/2013 model.
Thanks...
Users browsing this forum: rshales007 and 147 guests
