Problems engaging gears.
BenHol
Post by BenHol » Sat Jun 30, 2018 10:05 pm
Well today I seem to have developed a potential clutch problem I think. Going into all gears is difficult and actually grinds occasionally going between gears. The only confusing bit is there’s not clutch slip. On the odd occasion recently I have experience the clutch pedal sticking down. But not regularly.
Any thoughts on a diagnosis would be appreciated.
RS4 B7 - Phantom Black, 20in RS6 C7 alloys, Joey mod, detango, led drl, black optics, Bilstein b16, Michelin ps4s, centre res delete, black tips, 8mm spacers, vx lenses, RS embossed xenon, Carbon splitter, 034 ARB.
rickster147
Re: Problems engaging gears.
Post by rickster147 » Sun Jul 01, 2018 7:56 pm
First port of call change the slave cylinder first it's the cheapest option but not an easy job to do
Rs4 b7 In avus silver with b14 Bilstein coilovers, centre resonator delete with x pipe and piggie cats gutted
Headlights detangoed trups led kit drl reverse and numberplate kit
Previous audi
rs6 c5 - mrc stage 2 remap-itg filters-forge dumpers-center decat with miltek kw coilovers- h and r
I call her the growler lol
BenHol
Post by BenHol » Mon Jul 02, 2018 9:28 am
Thanks for that I’ll chat to mechanic.
mikep99
Post by mikep99 » Mon Jul 02, 2018 9:40 am
Might be a good idea to get robnic's uprated clutch pipe fitted while you're at it - see viewtopic.php?t=118361
Mike
Callumrobin
Post by Callumrobin » Thu Jul 05, 2018 1:51 pm
Had the same problem with mine, especially when the engine was hot, ended up changing the lot, clutch, cylinders and did the upgrade pipe at the same time, costly but drives like a new car now!
Covkiller
Post by Covkiller » Thu Jul 05, 2018 2:39 pm
+1
12th
Post by 12th » Thu Jul 05, 2018 4:09 pm
Clutch pedal sticking down - I had this after enthusiastic driving and changed many things. Clutch fluid with a higher boiling point was all it needed. Do this before you do anything more drastic, as it costs peanuts in comparison. evo highlighted a similar issue with the hotter Focuses, and it's clearly an RS4 issue too.
It does sound like you have other issues as well, though.
Sprint Blue B7 RS4 Saloon with MRC tweakery.
Users browsing this forum: Google Adsense [Bot] and 195 guests
