Intermittent P1555 fault code
MountainMutant
Post by MountainMutant » Wed Jun 27, 2018 4:11 pm
Car playing up today agin with boost (or lack of).
Had it scanned and the fault says 'Charge Pressure Maximum Limit Exceeded P1555 Upper limit reached - Intermittent'
I have a post further down where someone mentioned the brake switch but that seems fine.
Anyone had the above and what was the cure? I'm thinking N75 valve which has never been replaced but could it be anything else?
MM
2017 RS6 PE Nogaro 💙
GreggPDX
Re: Intermittent P1555 fault code
Post by GreggPDX » Wed Jun 27, 2018 4:52 pm
N75 was the culprit when I was getting that code. The valve had not completely failed, but was slow to react, so under hard acceleration in a higher gear, it would throw the code and go into limp mode.
Other possibility is a leak in one of the various lines to/from the turbos. Replacing the N75 valve is the easiest, but most expensive test. You can also disconnect the wastegate line from the N75 and put pressure to it to make sure it holds the pressure, and the wastegates are opening. If so, then it's back to replacing the N75.
Good luck!
MountainMutant
Post by MountainMutant » Wed Jun 27, 2018 5:28 pm
Is there just one valve or one for each turbo?
Post by Shoppinit » Wed Jun 27, 2018 8:24 pm
Just one.
Could be pressure sensor but my money's on the N75.
GreggPDX
Post by GreggPDX » Wed Jun 27, 2018 9:54 pm
Yeah, and unlike pretty much everything else on these cars, it's pretty easy to get to. Just remove the air cleaner assembly and it's hanging off the back of the intake manifold.
Users browsing this forum: Google Adsense [Bot] and 163 guests
