Dropping the gearbox out
Gavinda
Post by Gavinda » Sun Jun 17, 2018 7:01 pm
In the process of swapping to an 01e 6speed. Just looking for a bit of advice on certain parts of the swap.
Does the box come off with the turbos in place? Managed to get both the downpipes off and all the bellhousing bolts including the top two :rocker:
but something is stopping the box from sliding off. torque convertor backing plate bolts are off , do i need to do something else with torque conv back plate?
Re: Dropping the gearbox out
Post by bam_bam » Sun Jun 17, 2018 7:40 pm
Usually have to drop the engine with the box.
Gavinda
Post by Gavinda » Sun Jun 17, 2018 7:52 pm
Ive dropped the engine down a bit, but i was hoping not to take the whole lot out . Subframe is off ofcourse.
benh999
Post by benh999 » Sun Jun 17, 2018 7:56 pm
Apparently that gearbox chap in London drops the box with engine in situ?
Post by Shoppinit » Sun Jun 17, 2018 7:59 pm
It's possible. When I went to 512 trans they told me that no one had told them that the box had to be removed with the engine so they just removed the box.
Post by bam_bam » Sun Jun 17, 2018 8:10 pm
So there we have it, use the gearbox chap in London or 517 trans...
Gavinda
Post by Gavinda » Sun Jun 17, 2018 8:14 pm
lol
bilko1
Post by bilko1 » Mon Jun 18, 2018 7:51 am
Have you undone the torque converter to drive plate bolts?
Gavinda
Post by Gavinda » Mon Jun 18, 2018 11:00 am
Yes, taken those bolts out , accessed from the starter hole,. Think gearbox is just being a bit awkward, gonna change angles slightly and see if its just a bit of weight holding the torque convertor into the end of the crank.
benh999
Post by benh999 » Mon Jun 18, 2018 1:21 pm
Is this all being done off stands or have you access to a ramp?
Mɐʇʇ
Post by Mɐʇʇ » Mon Jun 18, 2018 6:39 pm
Most important, IIRC. Keep the TC on the box. The mistake I made the 1st time was as I pulled the box off, the TC came half off the gearbox too. TC must stay 100% home on the gearbox input shaft, then you don't need to remove turbos. (I think, it was a while ago)
Gavinda
Post by Gavinda » Mon Jun 18, 2018 9:02 pm
On stands , but is over the pit. Engine is held on a brace bar. Gearbox being supported by a gearbox jack( tall jack with cradle) front subframe is off.
Ben_r1
Post by Ben_r1 » Tue Jun 19, 2018 4:36 pm
Looking at it I would have thought it’d be easier just to remove the engine and box complete, seen this done on someone’s driveway before with relative ease.
PipRS6
Post by PipRS6 » Tue Jun 19, 2018 4:41 pm
Possibly a stupid question but if the car is over a pit what is the jack standing on?
benh999
Post by benh999 » Tue Jun 19, 2018 5:37 pm
Bottom of the pit I’d guess
Users browsing this forum: srichards and 245 guests
