Of course I turn it off, but it doesn't remember that I turned it off and keeps turning it back on again.
I hoping there is a way to make the car remember the setting or get it to default to off.
Has anyone found a way to fix this?
Thanks for the info.Brooner wrote: ↑Wed Jun 13, 2018 12:55 pmthere was a fix for the SQ5 i did it n my wife's one where it remembered the last setting
from MYAudiQ5.com it might be a similar coding
I can confirm the below vag mode works on my Q5 :
- module 09-Cent. Elec.
- enter Security Code (shown up by default) (mine i 20113)
- Adaptation, Type Channel 34 and hit Read button, it should show the factory default number.
subtract 4 to the value --> Start&Stop always disabled
add 32 to the value --> remember last status
- test & save
In addition of these values, if you add 64 to the value, the Start & Stop button light will be reversed: off if Start & Stop is disabled, and on if Start & Stop is enabled.
My car original number is 28, and I changed it to 60. So if the last time, Start /Stop is disable (light is on), then when engine is switch on next time it is still disable (light is still on).
Or if you wanna get rid off that extra light on button, just put in your car number + 64 and save it.
Cannot happier.
Users browsing this forum: No registered users and 4 guests
