Evening
I've just got VAG-COM and run an autoscan on the car for the 1st time and got these 2 errors back
Address 25: Immobilizer
Controller: Bit teA dre ss
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 35: Centr. Locks
Controller: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D13
Coding: 13130
Shop #: WSC 06325
3 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Can any body shed any light on them or are they ok to clear
Mike.C.
Fault codes
- ChipHazzard
RE: Fault codes
All fine, does key no 2 work? If not try replacing battery, clear codes and try opening car with key 2 again.
- ChipHazzard
RE: Fault codes
Both keys work fine, I cleared the codes alst night and will check again later to see if they reappear
FL Noggy S4 Avant
710N's, afterrun mod, MRC Generic Map & RS246 sticker
Kwack ZX7R & DRZ400 supermoto
RE: Fault codes
I had exactly the same code for key 2, but it didn't work on the car. I had to go to local Audi service to get it adapted again to immobilizer.
