Aircondition issue
Gary(rs4)87
Aircondition issue
Post by Gary(rs4)87 » Sun Jun 03, 2018 5:26 pm
Guys why the AC is sometimes working sometimes doesn’t? And if I switch off the AC then coming in to the cabin from the dash .
Usually after driving a car there is a few water stain under the car but now I noticed a huge
Could be the AC dryer?
klausy
Re: Aircondition issue
Post by klausy » Sun Jun 03, 2018 11:12 pm
When was your A/c system last properly serviced ??? Does the air conditioning work when you are driving and seem to stop working when you are stationary ?
Gary(rs4)87
Post by Gary(rs4)87 » Mon Jun 04, 2018 12:00 am
klausy wrote:When was your A/c system last properly serviced ??? Does the air conditioning work when you are driving and seem to stop working when you are stationary ?
It Was recharged last June, and im just noticed that if Im driving more than 30min stop blowing cold air, then if I switch off and on again, working for 10-15 min.
And If I turn the AC maximum speed than the water leaking under the car, i know it is a condensation but its a huge .
klausy
Post by klausy » Mon Jun 04, 2018 11:08 pm
If I were you I would get an Air conditioning specialist ( definatly not Halfords or Kwik Fit ) to properly service your a/c system , ask whoever does it to triple vac it with Oxygen free nitrogen , it sounds like your accumulator drier might be freezing up due to excessive moisture . Where abouts in the country are you ?
Gary(rs4)87
Post by Gary(rs4)87 » Tue Jun 05, 2018 1:13 am
klausy wrote:If I were you I would get an Air conditioning specialist ( definatly not Halfords or Kwik Fit ) to properly service your a/c system , ask whoever does it to triple vac it with Oxygen free nitrogen , it sounds like your accumulator drier might be freezing up due to excessive moisture . Where abouts in the country are you ?
UK, i already booked the car for service so they will checking the AC. But they said the same that probably blocked. Hope will be all right
Jezza1644
Post by Jezza1644 » Tue Jun 05, 2018 11:09 pm
Guys why the AC is sometimes working sometimes doesn’t? And if I switch off the AC then Image coming in to the cabin from the dash .
Usually after driving a car there is a few water stain under the car but now I noticed a huge Image
I had a similar issue about 6 months ago and it was the receiver dryer that had become clogged up. OEM part (8E0820193J) was megabucks so got one from states 'Comfortauto' https://www.ebay.co.uk/itm/332211968564 ... Tags=bu=bu for $26.99 plus $36.00 freight $62.99 total which was about £50 - not a bad saving! The killer is the labour which took 3.5 hours. The air-con is now all working OK, nice and cold as it should be.
Gary(rs4)87
Post by Gary(rs4)87 » Tue Jun 05, 2018 11:33 pm
I hope they can sorted without fitting new drier. This is how is looks the pipe. Frost. They said they try to recharge the system and we will see how it is work.
Jezza1644
Post by Jezza1644 » Wed Jun 06, 2018 12:04 am
Looks like the pipe could be blocked by a clogged up drier. If you get a new drier fitted you'll have to pay for fresh re-charge anyway. So if it turns out to be the drier and you get one fitted you'll end up having to paying twice for a recharge! Try to get a dedicated air-con specialist to test it rather than a dealer...
Gary(rs4)87
Post by Gary(rs4)87 » Wed Jun 06, 2018 12:05 am
Jezza1644 wrote:Looks like the pipe could be blocked by a clogged up drier. If you get a new drier fitted you'll have to pay for fresh re-charge anyway. So if it turns out to be the drier and you get one fitted you'll end up having to paying twice for a recharge! Try to get a dedicated air-con specialist to test it rather than a dealer...
Yes they will check it first. I hope will be fine
Jezza1644
Post by Jezza1644 » Wed Jun 06, 2018 12:10 am
yes good luck! :beerchug:
Users browsing this forum: 666Lenine, Bing [Bot], Google [Bot], Google Adsense [Bot], Zyox and 196 guests
