Blasted oil seal repaired by The Phirm
5.0 V10 50v biturbo - 571 bhp
House89
Post by House89 » Fri Apr 27, 2018 2:02 am
So I just picked my car up from The Phirm.
They had it for a week while I was in America.
Got this out
New one installed
Along with a new water pump drive as the edges of the hex were worn on both ends, something to look out for, it could have gone back in but Paul wasn’t happy with it so it was changed.
Brand new water pump installed too as there is an oil seal inside that, always best to change despite the cost, nearly £330 (from memory)
I also had a new radiator as mine had a tiny weep
Paul here doing his thing
They do the whole thing with the engine in the car, can do it as a drive in drive out job in 2 days. Using all genuine Audi parts. Total job comes in at around £2250.
The Phirm will also do the coolant pipes with the engine in, not a cut and shut job, they replace the entire coolant pipes with Audi genuine items for around £750.
If you’re based in the south and you need these big jobs done on your C6 then give Paul or Tim a call ‭01276 36848‬ and book it in.
moss
Re: Blasted oil seal repaired by The Phirm
Post by moss » Tue May 01, 2018 8:04 am
Great guys , they replaced my coolant pipes with engine in place , perfect job :)
House89
Post by House89 » Tue May 01, 2018 10:27 am
moss wrote:Great guys , they replaced my coolant pipes with engine in place , perfect job :)
I’ve been using them for nearly 15 years! They do all our VAG stuff for the business aswell.
PharkFunt
Post by PharkFunt » Tue May 22, 2018 5:56 pm
Also just had this done by the Phirm and can also recommend , had coolant lines and oil leak done plus a new oil cooler and oil lines. all done engine in :-)
would recommend these guys for others looking to get these two common areas sorted.
House89
Post by House89 » Tue May 22, 2018 5:57 pm
PharkFunt wrote:Also just had this done by the Phirm and can also recommend , had coolant lines and oil leak done plus a new oil cooler and oil lines. all done engine in :-)
Saw your car in there on Friday!!
Users browsing this forum: No registered users and 244 guests
