Front Wheel Spacers
BenHol
Front Wheel Spacers
Post by BenHol » Wed Apr 25, 2018 12:03 pm
After some opinions,
Do you think there would be a problem running 5mm or 8mm spacers on the front wheels to enable upgraded wheels to clear the calipers but not running any on the back? or maybe running narrower spacers on the back?
Any thoughts would be appreciated especially if anyone has experience of it.
Was wondering if the wider front track might reduce understeer?
RS4 B7 - Phantom Black, 20in RS6 C7 alloys, Joey mod, detango, led drl, black optics, Bilstein b16, Michelin ps4s, centre res delete, black tips, 8mm spacers, vx lenses, RS embossed xenon, Carbon splitter, 034 ARB.
FaisalJ
Re: Front Wheel Spacers
Post by FaisalJ » Wed Apr 25, 2018 12:58 pm
The OEM front track is actually slightly narrower than the rear (I forget by how much but think it’s 10mm difference)
I’ve run wider front spacers than rear (due to caliper clearance up front, and arch clearance at rear) that effectively evened out front and rear track widths. No negative effects noted.
Note, you can’t get a hubcentric 5mm spacer. 8mm is the smallest size for hubcentric.
2007 RS4 B7 Avant
MrHilario
Post by MrHilario » Wed Apr 25, 2018 1:42 pm
Wouldn't it look a bit odd with front spacers but not rear? Might as well go 8mm all round
1.4 Fiesta (Silver)
2.8 VW Bora V6 4motion (Blue)
4.2 Audi RS4 B7 Avant (Black)
BenHol
Post by BenHol » Wed Apr 25, 2018 5:25 pm
Iv Tried them on and with normal driving doesnt seem to feel any different, and dont think it looks odd at all. Actually not that noticeable. The problem is with the wheels I have fitted and 8mm spacers on the back the tyre catches the rear arch, I might try 5mm on front and back and see if that misses the calipers and the rear arch, althou then I wont be able to run hubcentric!!!
Id like to run no spacers at all but the front wheels wont clear the caliper that way.
Bowders1
Post by Bowders1 » Wed Apr 25, 2018 5:45 pm
Dont run no hub centric you will get wheel wobble
MrHilario
Post by MrHilario » Thu Apr 26, 2018 7:43 am
As above, do not run non hub-centric.
What size tyres are on the wheels? Are they 20" wheels?
Lots of people run 8mm and even 10mm with zero rubbing, not sure why yours is rubbing.
1.4 Fiesta (Silver)
FaisalJ
Post by FaisalJ » Thu Apr 26, 2018 11:31 am
MrHilario wrote:As above, do not run non hub-centric.
Non OEM wheels I believe?
Wheel width, offset, concavity (is that a word?) all come into play
2007 RS4 B7 Avant
BenHol
Post by BenHol » Thu Apr 26, 2018 12:51 pm
Yeah running the RS6 C7 Wheels which are 9.5j with et35 offset, so tight on the rear with spacers.
Think ill either stick with the 8mm hubcentrics on the front or maybe get them machined down as I reckon I only need 4-5mm to clear the caliper.
docurley
Post by docurley » Thu Apr 26, 2018 5:00 pm
Remove the wheel liners that might help.
Post by MikeFish » Thu Apr 26, 2018 7:56 pm
Just get the 5mm spacers on the front. Your wheel bolts should make sure the wheel sit central. If you get wheel wobble jack the car up and try undoing and redoing the wheel bolts again.
Post by MikeFish » Thu Apr 26, 2018 7:58 pm
What tyres you running? A different size or brand could will make a difference. But others run these wheels without rubbing so you should be ok with the correct spacers.
Markp
Post by Markp » Thu Apr 26, 2018 9:39 pm
RS6 are ET21 aren't they?
Post by MikeFish » Fri Apr 27, 2018 12:15 am
Yes the 9.5j 20s are ET21
BenHol
Post by BenHol » Fri Apr 27, 2018 7:16 pm
MikeFish wrote:Yes the 9.5j 20s are ET21
Yeah et21
Neilb76
Post by Neilb76 » Sun Apr 29, 2018 12:21 pm
Of anyone needs 8mm H&R spacers i have some forsale
Users browsing this forum: Google Adsense [Bot] and 370 guests
