Alternator
5.0 V10 50v biturbo - 571 bhp
993turbo
Alternator
Post by 993turbo » Wed Apr 11, 2018 10:47 am
So, it seems that a bearing has gone in my alternator. :audibash: I have bought a new alternator.
Has anyone changed the alternator? Any write-ups hints or tips...?
RS6 MTM C6 Avant (Daily Driver)
360 Modena (manual)
F430 Spider (F1)
+ 4 classic Porsches
Jim Haseltine
Re: Alternator
Post by Jim Haseltine » Wed Apr 11, 2018 12:39 pm
Can't find much info some say it's a front end strip but this thread viewtopic.php?f=47&t=126708&p=866305&hi ... or#p866305 doesn't.
993turbo
Re: Alternator
Post by 993turbo » Wed Apr 11, 2018 1:03 pm
Oki, cheers. The thread you linked to was just for the tendioner and belt, not the alternator itself? Or..?
360 Modena (manual)
F430 Spider (F1)
Jim Haseltine
Re: Alternator
Post by Jim Haseltine » Wed Apr 11, 2018 2:02 pm
Ah, yes - sorry. I was concentrating more on the diagram. Other web searches imply that there's a fair amount of stripping required to get access to some of the fittings.
993turbo
Re: Alternator
Post by 993turbo » Sat Apr 21, 2018 2:57 pm
Bumper/undertray off. Headlights out. Pull the front out into “service position”. This gives access to the belt/tensioner and alternator. About a 4hr job in total.
Note that oil / coolant must be drained.
360 Modena (manual)
F430 Spider (F1)
Re: Alternator
Post by bam_bam » Sun Apr 22, 2018 7:44 pm
Wow, simple job! Isn't the C6 alternator water-cooled?
993turbo
Re: Alternator
Post by 993turbo » Mon Apr 23, 2018 1:13 pm
Yes. Watercooled.
360 Modena (manual)
F430 Spider (F1)
Rs6Rob
Re: Alternator
Post by Rs6Rob » Thu Apr 26, 2018 5:00 pm
It is a pig to try and do with the radiators in the service position, book says to remove the rads
RS6, C6, 2009, MRC Stage 2, Aquamist Water/Meth injection, secondary CAT’s deleted, BMC Filters, Headlight Upgrade second projector with RS lens - Trupps supplied the parts I built myself. Interior LED upgrade, C7 RS gear knob upgrade, AutoTecknic Shift Paddle Extensions, KW V3 Coil-overs, H&R ARB's, H&R spacers 8mm Fr & 10MM R.
On the cards - Primary CAT delete, TTE Turbos
