FLAC Files on MMI
wazaB
FLAC Files on MMI
Post by wazaB » Mon Apr 09, 2018 6:00 am
Morning
Has anyone managed to update the MMI firmware to allow FLAC (and other lossless) files to be played?
W
Re: FLAC Files on MMI
Post by MikeFish » Mon Apr 09, 2018 6:36 am
What year car do you have? My MY2016 played FLAC from the factory.
wazaB
Post by wazaB » Mon Apr 09, 2018 7:46 pm
64 plate Mike. My RS3 8V even plays FLAC. Wonddring if I can swap out the base units, but not sure...!
Post by MikeFish » Mon Apr 09, 2018 8:33 pm
I'd be amazed if you could swap the RS3 unit into the RS6, I thought they were completely different.
You can retrofit the later unit I think but I don't think it's cheap. Also the facelift cars changed to a different bus system (went from MOST50 to MOST150 so not sure you can even fit a facelift unit in a non facelift cars.
wazaB
Post by wazaB » Tue Apr 10, 2018 12:08 am
All I want is to be able to play FLAC. Surely there must be a firmware update...!!
Post by MikeFish » Tue Apr 10, 2018 12:42 am
Try giving HazzyDayz a call. he should know if there is a firmware update that will sort you out.
https://www.hazzydayz.com/a6-4g-s6-4g-r ... 4-82-c.asp
wazaB
Post by wazaB » Thu Apr 12, 2018 7:52 pm
Thanks Mike, on the case
HDPete
Post by HDPete » Sun Apr 29, 2018 11:37 am
It may be worth a scroll through the software license page on the MMI Setup page. I stumbled across it the other day and found Gracenote and other plug in licenses, including Flac playback. It be that you do have it and possibly the encoding settings you use can’t be read by the open license plug in.
Users browsing this forum: No registered users and 111 guests
