Oil Cooler Options
Oil Cooler Options
Is there any alternative to the Forge Oil cooler kit out there? Mine has failed and Forge are quoting 2 weeks lead time to get hold of one, which is a bit of a pain!
Pistolpete2543
Re: Oil Cooler Options
Perfect thanks, I guess I'll need to go to Audi to get the pipes I need?
Pistolpete2543
Yeah, they’re OEM only. I think about £360 inc VAT for both.
Radtec can supply the pipes?
- SimonS4MTM
- Top Gear
I went OEM all round
Pistolpete2543
Ordered the Radtec, seems to be in stock thankfully.
Will speak to the mechanic tomorrow and see what else I’ll need.
Pistolpete2543
You will definitely need new hoses, both because the originals will almost certainly be rotten, but also you have virtually no chance of getting the original pipes off the cooler due to the dissimilar metals.
Mocal oil cooler. It’s what Forge place in there kit. The braided hoses are pretty cheap to get made up anyway.
johnsimister
- 1st Gear
custom csf i run much bigger core max temps on track 110
Softishman
More info pleasejohnsimister wrote: ↑Wed May 02, 2018 7:28 pmcustom csf i run much bigger core max temps on track 110
@softishman on IG
Check out my RS4 there!
- Bladerider
LOL
Oil cooler is an oil cooler - they're not magic, same with the pipes !!
mistercvee
I’ve gone for the Radtec option, with the JHM connection converters and JHM hoses. Quality of both the Radtec and JHM products are excellent, and look straightforward to fit...but I’ll find out this weekend
2006 B7 RS4 Sprint Blue Saloon
How did it all fit? Did you require any additional hardware? I’m considering a similar approach - Thanksmistercvee wrote:I’ve gone for the Radtec option, with the JHM connection converters and JHM hoses. Quality of both the Radtec and JHM products are excellent, and look straightforward to fit...but I’ll find out this weekend
Sent from my iPhone using Tapatalk Pro
Users browsing this forum: Bing [Bot] and 332 guests
