fault code`s
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
quattro999
Post by quattro999 » Thu Nov 17, 2005 9:57 am
up here in tayside / scotland , so if any one near this area that can help,,
all road test again tonight and see if its the same ,,
but would that be related to cam position sensor ??
buzzard
Post by buzzard » Thu Nov 17, 2005 2:46 pm
got my new maf on and at first seems a bit groggy but after a fewe miles its starting to come alive again. will do a log again to compare figures when i get chance but bit up to neck init.
S4 B5 long gone
S4 B8 Stage 2
S2tuner
Trader (Expired)
Post by S2tuner » Thu Nov 17, 2005 2:58 pm
you need to reset the fault codes so you reset the ECU's adaptive memory as well just after you replace the MAF, otherwise it won't run right for a while...
quattro999
Post by quattro999 » Thu Nov 17, 2005 9:42 pm
gave the car a bit road test once upto temp,, the kangaroo feeling has gone and pulls good , , but will still fit maf as its due to be fitted hopefully midweek at the latest ........
fault code 4552 .. cam position sensor would that be related to maf ?? :oops:
KayGee
Post by KayGee » Fri Nov 18, 2005 1:30 am
Mine was miss behaving generally, most noticeable when cold, miss firing, jerky throttle response when pulling away, new MAF sorted this out totally.
ChrisG
Post by ChrisG » Fri Nov 18, 2005 3:10 pm
If the airbag code comes back you will need a new side bag IIRC about £170 incl fitting, tried three times to get her's fixed , cleaner, connections etc ( dealer didn't even charge on one occasion !!) but had to pay up after a couple of months fiddling / waiting/ cleaning .
ChrisG
buzzard
Post by buzzard » Mon Nov 21, 2005 10:16 pm
when you say reset the fault codes do you mean erase if they are present or is this another function?
car now feeling alot crisper throughout!
did the exchange deal at local dealers and was surprised to get part of the tubing too-- thought it would of just been the sensor itself.
need
to do a run now with new one fitted and will post both before and after readings on your other thread (the widely viewed euro block figures) when i get chance for future help for stock runners cus its bin a great help to me up to now! cheers.
quattro999
Post by quattro999 » Sat Nov 26, 2005 9:31 pm
new maf , and full service carried out ,,, not had time to give car a run to see if made any changes,, but still have fault code 4552.. cam pos sensor !!!!..
is this a case of replacement of sensor or ????.. and where is this sensor ??
Return to “DTC / VCDS”
