Coolant Loss
tommchowat
Coolant Loss
Post by tommchowat » Thu Mar 08, 2018 5:19 pm
Hi all,
During a nice leisurely drive I noticed steam coming out the left hand side of the bonnet and an odd smell. Parked up and left it running, car was pissing coolant all over my drive way. It's dripping off the undertray and gathering on the ground slightly to the passenger side of centre, about in line with the wheels.
Coolant level is way down, doesn't leak when the car is off though. Garage looking at it Saturday. Any thoughts on what to expect?
Tom
Surrey Sam
Re: Coolant Loss
Post by Surrey Sam » Thu Mar 08, 2018 5:28 pm
Aux rad.
tommchowat
Re: Coolant Loss
Post by tommchowat » Thu Mar 08, 2018 5:31 pm
Thought so, seems about time. What sort of cost are we looking at? Do you think it would be worth getting both of them done at the same time, or only fix when broken?
Pistolpete2543
Re: Coolant Loss
Post by Pistolpete2543 » Thu Mar 08, 2018 5:51 pm
I think a new aux rad is about £200. Need to remove front bumper to get access, but otherwise straightforward job. I don’t see the point changing both if only one is leaking, but it’s up to you.
tommchowat
Re: Coolant Loss
Post by tommchowat » Thu Mar 08, 2018 6:01 pm
Well long term I wanted to get rid of the driver side one and do an MRC cold air feed, so maybe I'll fix this one and leave the other.
Meanwhile, is there any way to make the car driveable from now until it gets fixed?
a1topdog
Re: Coolant Loss
Post by a1topdog » Thu Mar 08, 2018 6:59 pm
Top the coolant up and drive it. The aux rads only kick in when the car is really hot, eg in traffic etc, so should be fine for normal driving.
:redrs4: 2006 Misano Red RS4 Saloon. :redrs4:
tommchowat
Re: Coolant Loss
Post by tommchowat » Thu Mar 08, 2018 7:09 pm
Okay. I was stuck in traffic for ages just before it let go come to think of it. If I could pick up another radiator tomorrow I could have the car fixed by Saturday and not have to pull a sicky at work Monday.
Thanks for all the help.
Re: Coolant Loss
Post by MikeFish » Fri Mar 09, 2018 12:43 am
This. Don't let it get too hot and it won't lose any coolant. Other than that keep it topped up until you fix it.
a1topdog
Re: Coolant Loss
Post by a1topdog » Fri Mar 09, 2018 8:04 am
No one makes pattern rads, it genuine Audi only. If you have a TPS near you try there. They normally have them in stock.
Re: Coolant Loss
Post by MikeFish » Fri Mar 09, 2018 8:39 am
You could use the good one from the drivers side on the passenger side then put a cold air feed in.
Pistolpete2543
Re: Coolant Loss
Post by Pistolpete2543 » Fri Mar 09, 2018 9:21 am
OEM only.
Edited post as I was getting confused with oil cooler!!
Last edited by Pistolpete2543 on Fri Mar 09, 2018 10:32 am, edited 1 time in total.
tommchowat
Re: Coolant Loss
Post by tommchowat » Fri Mar 09, 2018 9:40 am
Thanks - I really need the car back on the road by Monday though so I'm gonna see if Audi have got one I can pick up.
tommchowat
Re: Coolant Loss
Post by tommchowat » Sat Mar 10, 2018 2:27 pm
Guys,
You're not gonna believe this.
Radiators all pressure tested and fine. I mentioned I saw air bubbles going through the coolant expansion tank as the coolant was leaking.
Did a test while it was running, air coming up and liquid changing colour. <beep> head gasket has gone. On a 68k mile car. Just as my warranty ran out too.
Livid.
Covkiller
Re: Coolant Loss
Post by Covkiller » Sat Mar 10, 2018 3:11 pm
Still go to Audi they may do it under good will.
tommchowat
Re: Coolant Loss
Post by tommchowat » Sat Mar 10, 2018 4:29 pm
Absolutely fuming about this. How could the car have such a catastrophic failure at 68k miles?!
With my M3 I sort of expected it. 2003, 95k miles, fine. But this...
Second performance car, second head gasket. I must be the unluckiest owner ever.
Users browsing this forum: No registered users and 125 guests
