Where can I buy engine under tray?
Gary(rs4)87
Anyone know where is the best place to buy engine undertray? Or someone can made by aluminium?
TPS charge 180+VAT
TPS charge 180+VAT
Re: Where can I buy engine under tray?
TPS or dealer only as they are a special tray totally different to std A4 to accommodate the air ducts to brakes. Your be hard pressed to find second hand that that is in any good condition. Mine was a wreck so I spent ages rebuilding it and using tiger seal on it to make it bit more harder wearing. The heat from engine makes the plastic very brittle and easy to break. I am gona get a oem one from TPS later on as I get discount . Getting a alloy one made up would be dam site more expensive to deal with the shape and contours to fit to all the hook up points imo.
Gary(rs4)87
Yes if no chance to find somewhere else than I will order from tps because mine totaly scrap
- Surrey Sam
£180 sounds rather cheap. Sure you got the right part number?
JCWF made an Aluminium one, so perhaps contact them. FaisalJ had one fitted, as seen in this thread - viewtopic.php?f=35&t=126627&p=865455&hi ... ay#p865455
Gary(rs4)87
As Iv heard jcwf 600£
And yes TPS 180+vat
And yes TPS 180+vat
Over £200 for a plastic undertray is bad enough but three times that for what is essentially a piece of aluminium is taking the p1ss, I see JCWF no longer Sponsor the site anymore?
Doesn’t have the holes/spire clips/cut outs for the brake ducts unfortunately
Users browsing this forum: Google Adsense [Bot] and 370 guests
