Hello everyone
I'm already to rebuild the engine. But I do not idea how can choose the bearing shell.
No.13 bearing shell
079 105 561 G (red)
079 105 561 H (yellow)
079 105 561 J (blue)
No.14 bearing shell
079 105 591 G (red)
079 105 591 H (yellow)
079 105 591 J (blue)
No.18 connecting rod bearing shell
079105701G ROT(red)
079105701G GLB(yellow)
079105701G BLA(blue)
Then about No.16 1 set of thrust washers, I check the website have 2 parts
THRUST BEARING - AUDI (078-198-421)
WASHER KIT - AUDI (078-198-421-A)
What different ??! The website, have not detailed can understand. How many quantities do I need to order?
Please, Help me!!
Thank you
How can choose the bearing shell No. (color)?
Re: How can choose the bearing shell No. (color)?
unfortunately its not straight forward as the different colours indicate the different sizes, you will need to accurately measure your crank to determine which colour combos you need to use.
have a read of this thread http://audirevolution.net/forum/index.php?topic=2624.0
maybe try to pm 65vetteC6 on audirevolution or audizine see if he can give you more info?
Thank you for your replaysar wrote: ↑Thu Mar 01, 2018 1:28 pmunfortunately its not straight forward as the different colours indicate the different sizes, you will need to accurately measure your crank to determine which colour combos you need to use.
I had read, help me. Yes, it needs to measure, I wrong.
This is my crankshaft, on to the rods were marked GGGG-YYYY. Then my technician checks Elsawin, in fact, this is work not easy for me.
But I do not understand, can not found each color the dimension by Elsawin?
In fact, I had seen the dimension on audirevolution.net yesterday. But it disappeared!! Fortunately, I had to take the photo this page. This is not correct data, so delete? I guess
However, my rebuild keep following, I'm ordering new parts in today, this is expensive. Let me want to cry...
Some sample photos
First preparation the parts
Is Big Guy
BBQ ing
Cleaning, bale then waiting for the second time parts arrival.
Thank you
Do you mind if I ask what mileage was on the engine before it needed the rebuild?
Current - 07 Avus Silver B7 RS4 Avant : Ceramics, Non Valved Non Res Milltek, K&N filter, SS+, adaptive xenons, black optics, KW3, 034 rear ARB, rear drop links & front adjustable top arms.
Past - 00 Saxo VTS : 266mm Mi16 calipers, Quaife ATB, 20mm torsions bars, 24mm ARB, Vibratechnics mounts
87 Vauxhall Belmont: 1.6L, 15" rockford fosgate subwoofer in 3 cuft sealed box, 5ch Rockford fosate amp, JBL components
I don't mind, I rebuild on 89,550km. My problem is very slight as some oil leaking, in the beginning, so just want change the O-ring and pipe. But the oil leaking between oil sump-upper and lower, so I need to remove the engine from the car. Then more the plans beginning, this is can't stop so I changing the must change parts, like the timing chain, tensioner, guide rail, bearing...does not finish. Even though my engine everything is ok, I still needed to be bought around 330 quantity as 88 parts(include first order), this is loss more cash, I cry. I waiting for the second shipping.irn_bru_ce wrote: ↑Wed Mar 07, 2018 8:50 pmDo you mind if I ask what mileage was on the engine before it needed the rebuild?
Update
About rod bearing, my supplier told me the 079105701GBLA Blue bearings are no longer available. I keep asking my supplier about this problem. Then Audi told him - the rod bearings as "model specific" and yellow as the only option for rod bearings, I shortened explained, keeping the emphasis and keyword.
Rod bearings have different force, so corresponds is on uppers and lowers as two specs, I think this is a simple physical process. Before, corresponds is yellow/blue the rod bearings by AUDI technological manual. Why the Audi change it now?
Now, I can't buy the Blue bearings from my supplier. So I try to find the purchasing agent, ordered new Blue bearings from Germany. Maybe I can get it in next week.
Update 2
I got the new parts two weeks ago.
The second parts. If you see it, I bought double the chain tensioner, is not correct, only need one. Because of this part has two number can use, only a little different is the white plastic length.
The Blue rod bearing, the part has been replaced by 079105701GGLB
Then measuring every the rod bearing
Rebuilding
70% - 80% finished, maybe
Then I don't know the injection valve is very hard to remove, damage to on the head. This is expensive
, I need order parts again for 8 injection valve with repair Kit. If you will remove or cleansing it, must be careful.
Next, I waiting for the "Equalizing Element Hydraulic of the inlet and exhaust valve" the rebuild.
Rebuilding
