oil level sensor
oil level sensor
hi guys just a quick one before i crack on with it can it be changed with oil still in the sump.
from looking at it Id like to say yes but i may loose some oil .
cheers guys
cheers guys
c6 rs6 avant- mrc stage 2 -current
bmw e61 m5 saloon
s3 8p stage 2
vw bora tdi hybrid turbo
bmw e61 m5 saloon
s3 8p stage 2
Re: oil level sensor
No issue changing the sensor with the oil in the tank. The oil level is below the opening for the sensor. I changed my two weeks ago as it was leaking.
RS6 C6 (Gone but not forgotten)
Golf R
Delorean DMC 12
Jaguar MK2
E-type
Golf R
Delorean DMC 12
Jaguar MK2
E-type
Cheers for that , just got it being serviced next week and it's packed in but only on the temp side which is strange
bmw e61 m5 saloon
s3 8p stage 2
bmw e61 m5 saloon
s3 8p stage 2
Hi
I have an issue with my sensor, how hard is it to change it? and do you have a part number for the sensor... how much did it cost please?
I can see the sensor in the oil tank, it looks tight i assume that you need to remove a few parts to get proper access to it.
thanks
thanks
Bumper and headlight removal required.
Sensor costs around 150 euro.
p/n 420907660
p/n 420907660
Assume V10's don't have that oil stick that you could check the oil "manually"
[novice user] Where (and how) would one check the oil level in the car?
Thanks.
Thanks.
2008 RS6 Avant (Monza Silver)
- H&R ARBs
- H&R ARBs
These cars are "dry sump" so the oil is not kept in the engine when you switch it off like a norm al car but is instead held in a separate oil tank which does have an "oil stick".
To check the level you must run the engine so that the oil gets upto operating temp and then, on level ground, switch the engine off and wait about 1 minute before checking the oil tank level. If you do this when the oil is cold the level will look lower than it should and you will over-fill the tank.
cheers Ian - much appreciated.
- H&R ARBs
- H&R ARBs
Curly Head
Sorry for jumping in but my car is now telling me that I have low oil even though when manually checked it’s fine.
Garage says there are 3 sensors and Audi are unsure which one it is!!
Have any of you fellas had this problem and / or fixed it with the above part no. mentioned?
95% of the time it's the one built in to the oil tank called the G266 sensor (combined oil level and temp). The Pt No is 420907660 and a new O-Ring is Pt No N90974501.
Curly Head
Thanks, I will give that a go
Jim Haseltine
Mine can be a pain at times. Friday night - 'please check oil level'. Sure enough, it was well down into the refill section on the dipstick, so I topped it up to just above the mark.Curly Head wrote: ↑Thu Jun 14, 2018 6:24 amSorry for jumping in but my car is now telling me that I have low oil even though when manually checked it’s fine.
Tonight, 'please check oil level' but this time it was only just under the line.
That seems to be it's usual method of operation in my car, two warnings within a few days and then nothing for weeks.
Hard to get to and bugger to check... could be down to faulty (or loose) connector.
I'd suggest to replace at the next oil change.
- H&R ARBs
- H&R ARBs
Curly Head
Mine is definitely intermittent too, will get it swapped over at the next oil changeJim Haseltine wrote: ↑Mon Jun 18, 2018 10:20 pmMine can be a pain at times. Friday night - 'please check oil level'. Sure enough, it was well down into the refill section on the dipstick, so I topped it up to just above the mark.Curly Head wrote: ↑Thu Jun 14, 2018 6:24 amSorry for jumping in but my car is now telling me that I have low oil even though when manually checked it’s fine.
Users browsing this forum: Google Adsense [Bot] and 60 guests
