burning oil smell?
5.0 V10 50v biturbo - 571 bhp
pcorpe
burning oil smell?
Post by pcorpe » Mon Feb 19, 2018 8:22 pm
no recent oil changes, no leaks underneath, no puddles in the garage, however, i'm getting a burning oil smell, not all the time but most.
I think it's emanating from near the air intake tube (maybe?) not sure.
anyone else found and solved this one?
DJ Kill
Re: burning oil smell?
Post by DJ Kill » Mon Feb 19, 2018 10:56 pm
Looking for same problem about a year! No luck...
And all oil levels (engine, hydraulic) stays stable!
So, check all oil levels (gearbox may be a bit complicated). This will narrow your search.
Or remove the engine and inspect everything. Finally you will remove the engine to fix it... It's RS6. :)
P. S. I think most common place - O-ring under oil filter you replace just because "if in doubt - replace O-ring"? :D
Jim Haseltine
Post by Jim Haseltine » Mon Feb 19, 2018 11:49 pm
The ribbed breather pipe that goes to the top of the oil tank is prone to going brittle - looks fine but can be cracked allowing fumes out.
Then as soon as you touch it it ends up in pieces in your hand.
Only other thing I've heard of is the cam chain covers leaking down onto the down pipes - about the only way you'll find that (and certainly the only way you'll seal them) is to drop the engine & 'box.
DJ Kill
Post by DJ Kill » Tue Feb 20, 2018 9:06 am
Also head covers sealing. Rear crankshaft sealing.... Many more options.
pcorpe
Post by pcorpe » Tue Feb 20, 2018 9:12 am
Thanks for the suggestions chaps, the breather pipe sounds the most obvious place to start, but i've noticed the issue is both sides of the block, i've even seen oil smoke on the passenger side (RHD) so has to be something that is duplicated. that makes me think head covers or cam chain area.... humm what fun, let the games commence.
Jim Haseltine
Post by Jim Haseltine » Tue Feb 20, 2018 9:35 am
If you mean the big O ring seal on the oil filter screw cap, then that should be replaced every time the cap is removed because they don't reseal properly.
DJ Kill
Post by DJ Kill » Wed Feb 21, 2018 12:12 am
No, this O-ring is the part of the filter.
I mean that part: 079103121BE
Between oil filter bracket and engine.
Users browsing this forum: hartley1967 and 44 guests
