RS6 C7 | Spacers, whats BEST combo?
- finance-nick
- 1st Gear
Hi all,
I want to space my 21" alloys, and thinking 15mm front, and 20mm rear, im trying to acheive the absolutely perfect look like this one below, does anyone have experience of what fits best?
Re: RS6 C7 | Spacers, whats BEST combo?
That car is lowered. How low you go will dictate what spacers you need.
I run 15mm rear spacers and none on the front with my 21s and 12mm spacers with my 20s. Both sets rub at the front.
That is with 40mm springs all round.
Older cars sit a little more level in my opinion.
With my 21s and 20s
Sent from my SM-G935F using Tapatalk
- finance-nick
- 1st Gear
I will be lowering 20mm
This is a close shot of 15mm rear spacers. 20mm rear might work but it'll be close.
I went 12 and 15. Mines running air and it occasionally rubs on the front when in dynamic suspension.
Approx 25mm drop
15mm front Spacers
20mm rear Spacers
15mm front Spacers
20mm rear Spacers
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
becausephilchow
I ordered 15MM and 12MM, will be installing next week. OEM 21s Non-PP, hopefully should be OK and not rub.
Have KW HAS to be installed, but lowering maybe about 25MM Max, not too much at all.
I have 15mm front/20mm back with Cete lowering module as on air... the spacers work perfectly and I just had to adjust the ride height carefully to ensure absolutely zero rubbing. Fronts are nicely tucked with the geo I had done at Centre of Gravity and back sit flush.finance-nick wrote: ↑Mon Feb 05, 2018 1:18 amHi all,
Steve
- finance-nick
- 1st Gear
Yossarian wrote: ↑Mon Feb 05, 2018 11:42 amI have 15mm front/20mm back with Cete lowering module as on air... the spacers work perfectly and I just had to adjust the ride height carefully to ensure absolutely zero rubbing. Fronts are nicely tucked with the geo I had done at Centre of Gravity and back sit flush.finance-nick wrote: ↑Mon Feb 05, 2018 1:18 amHi all,
Steve
Any pics Steve?
think im sold on 20mm and 15mm
HonestYossarian
Here you go:finance-nick wrote:Yossarian wrote: ↑Mon Feb 05, 2018 11:42 amI have 15mm front/20mm back with Cete lowering module as on air... the spacers work perfectly and I just had to adjust the ride height carefully to ensure absolutely zero rubbing. Fronts are nicely tucked with the geo I had done at Centre of Gravity and back sit flush.finance-nick wrote: ↑Mon Feb 05, 2018 1:18 amHi all,
Steve
Any pics Steve?
- finance-nick
- 1st Gear
wow looks great thanks steve, what drop is that?
Thanks - not sure of the actual drop from standard air height but on the Cete lowering module is 10mm lower than standard Dynamic (which is already quite low on factory air). I'm really pleased with it now.
Steve
Very nice
I’m on DRC and don’t think it’s really worth the cost to lower it. If I did it would only be 10mm as I have to see a gap between tyre and arch. Silly I know just a personal thing,hate it when the top of the tyre isn’t visible
Has anyone had 10mm front and 15mm rear combo just to keep the tyre inside the arch.
Users browsing this forum: Google [Bot] and 112 guests
