High pressure fuel pump issue
Gary(rs4)87
Post by Gary(rs4)87 » Tue Jan 16, 2018 11:36 am
Hi guys,
Engine management light on because of high pressure fuel pump.
Anybody have a spare one? Or better to order new one? Enough for one side or better replacing both side?
jon_273
Re: High pressure fuel pump issue
Post by jon_273 » Sun Jan 21, 2018 9:32 am
I replaced one side because of a small leak and it still runs fine. Don't see why both sides would need replacing.
Gary(rs4)87
Post by Gary(rs4)87 » Sun Jan 21, 2018 9:33 am
Thanks, but now no issue, running fine,
12th
Post by 12th » Sun Jan 21, 2018 2:55 pm
Had one replaced last year, and wondered about the other. No problems since. No warning light, but the car had massive flat spots and interruptions to power from the mid range up - it felt horrible to drive. You'll know if and when you need the work...
Sprint Blue B7 RS4 Saloon with MRC tweakery.
Gary(rs4)87
Post by Gary(rs4)87 » Sun Jan 21, 2018 3:44 pm
Not feel any difference now, but if coming back than I will order one.
When I went home few days ago just lost the power and huge smoke from the driver side exhaust and then engine management light come off, then the garage told me. The bank 2 high pressure fuel pump issue, and caused missfire 5 and 8 cylinder
But now its ok again
12th
Post by 12th » Sun Jan 21, 2018 4:28 pm
Hmm. I'm not sure that I'd expect a fuel pump to have that sort of problem and then fix itself, so maybe it was something else? And if it ain't broken...
Gary(rs4)87
Post by Gary(rs4)87 » Sun Jan 21, 2018 4:29 pm
The guys said to me probably the fuel filter is too old and was fuel issue
TheBigFish
Post by TheBigFish » Fri Dec 30, 2022 4:40 pm
Hi guys! Looks like I might have an HP pump failure on my RS3 B8.5 as well. Any idea how I diagnose which one has failed? Got the following fault codes:
2838 - Fuel Rail/System Pressure
P0087 00 [101] - Too Low
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 79049 km
Date: 2022.12.29
Time: 08:49:26
Engine RPM: 2112.50 /min
Normed load value: 87.5 %
Vehicle speed: 75 km/h
Coolant temperature: 46 °C
Intake air temperature: 11 °C
Ambient air pressure: 970 mbar
Voltage terminal 30: 14.277 V
Unlearning counter according OBD: 40
Engine status-Bits 0-7: 3
Engine oil temperature: 42.6 °C
Engine operating condition: Part throttle
Engine operating condition-Test_Program_Channel 87: 6
17895 - Valve for High-Pressure Fuel Pump
P12A3 00 [100] - Stuck Open
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 79051 km
Date: 2022.12.29
Time: 08:51:04
Engine RPM: 1385.50 /min
Normed load value: 82.7 %
Vehicle speed: 35 km/h
Coolant temperature: 56 °C
Intake air temperature: 13 °C
Engine oil temperature: 47.0 °C
17899 - Fuel Rail/System Pressure
P0087 00 [100] - Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 79051 km
Date: 2022.12.29
Time: 08:51:58
Engine RPM: 1279.50 /min
Normed load value: 89.0 %
Vehicle speed: 0 km/h
Coolant temperature: 53 °C
Intake air temperature: 14 °C
Voltage terminal 30: 12.910 V
Engine oil temperature: 50.6 °C
7697 - Oxygen (Lambda) Sensor B2 S1 Voltage too Low / Air Leakage / Sample Error
P2415 00 [101] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 79051 km
Date: 2022.12.29
Time: 08:51:31
Engine RPM: 986.50 /min
Normed load value: 16.1 %
Vehicle speed: 25 km/h
Coolant temperature: 54 °C
Voltage terminal 30: 14.418 V
Engine oil temperature: 47.8 °C
Engine operating condition: Idle
Engine operating condition-Test_Program_Channel 87: 5
Driver-side belt buckle status-Bits 0-7: 62
Current system status: SYC_DRIVE
Current system status-Test_Program_Exe Con State 02 UBYTE: 4
7683 - Oxygen (Lambda) Sensor B1 S1 Voltage too Low / Air Leakage / Sample Error
P2414 00 [101] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 79051 km
Date: 2022.12.29
Time: 08:51:31
Engine RPM: 990.50 /min
Driver-side belt buckle status-Bits 0-7: 61
Users browsing this forum: Google [Bot] and 262 guests
