Aftermarket head unit to replace RNS-D
benh999
Re: Aftermarket head unit to replace RNS-D
Post by benh999 » Wed Nov 15, 2017 10:50 am
So I fancy this unit, can some one post up the link for the correct Fascia surround and loom adaptor please?
mikep99
Post by mikep99 » Wed Nov 15, 2017 11:20 am
I would think something like this should do it:
http://www.ebay.co.uk/itm/Double-Din-Ca ... SwPe1T27l3
I'd try and get the unit, faceplate & loom from the same retailer - speak to them first and confirm it suits your needs. They should be able to tell you if you need anything else...
Mɐʇʇ
Post by Mɐʇʇ » Wed Nov 15, 2017 11:37 pm
I'm afraid I can't quite remember the exact kit I used to fit it - I have a vague recollection it was the connects2 - http://www.connects2.co.uk/Product/ProductItem/CTKAU05
You have a choice then of either using the connects 2 cage & surround or the pioneer one.
Cyg1y
Post by Cyg1y » Sun Nov 26, 2017 12:59 am
Quick Q
Does the Pioneer allow you to play CD s in the CD player in the boot?
Does the Pioneer connect to the GPS aerial on the roof? Or does the GPS location depend on a signal to the phone-?
simonpoulton
Post by simonpoulton » Sun Nov 26, 2017 7:48 am
1. Not sure. I exclusively use Spotify now for music through the head unit.
2. Has its own gps but it’s only used for setting the time as you use apple maps for navigation. That runs off the gps on your phone. Works really well unless you don’t have internet
Past: R56 Mini Cooper S
Mɐʇʇ
Post by Mɐʇʇ » Sat Dec 02, 2017 11:08 pm
Just for reference - not the best picture, but you get the idea...
Mark-RS
Post by Mark-RS » Sat Jan 20, 2018 7:21 pm
Does anyone know if there is a main Live and a switched live in the loom ? Or will I need to patch them in ?
Head unit has now arrived, as has the wiring loom/adapters so as soon as the rain stops pissing it down I'll be out having a play ! Just wondering if it's going to be a simple 10 minute plug and play or if I am going to have to be adding in extra wires myself ?
HPsauce
Post by HPsauce » Sat Jan 20, 2018 7:32 pm
There must be; have a look at the wiring layout on the back of the RNS to check.
(I know there is in the lead out to the CD changer so it must be there on the input)
Ajc
Post by Ajc » Sat Jan 20, 2018 7:38 pm
It should be a simple plug and play .
However , make sure the amp is switching off and not staying live as this is common for draining the battery
Cheers Al
Mark-RS
Post by Mark-RS » Sat Jan 20, 2018 7:40 pm
Thanks, hopefully tomorrow is a dry day then. And not cold either !
Mark-RS
Post by Mark-RS » Mon Jan 22, 2018 6:08 pm
For some reason this appears to be what I have behind my dash. Plugging everything in seems to allow me to turn everything on with ignition and it goes off with ignition, but I don't seem to have any sound at all !
Looking at the wiring it appears that half the speaker wires go to one plug ? And half go to the other ?
Is this even standard wiring ? Or has it been played with before ?
Of the 2 black plugs, the one on the right seems to give the power, but the one on the left I have zero idea what they are ? Don't think they are speaker wires ? As I though those were the grey, green etc which are split amongst the other plugs ?
Mɐʇʇ
Post by Mɐʇʇ » Mon Jan 22, 2018 10:44 pm
I'm afraid I honestly can't remember. :(
simonpoulton
Post by simonpoulton » Tue Jan 23, 2018 1:20 pm
Yeah that looks different to mine. That red bullet connector in pic 3 is not standard I dont think.
The aftermarket adaptor I got was this one from amazon. The blue bullet connector I think was for the remote to the sub (if you put this on the wrong one, it keeps the amp running all the time)
It's really hard to remember!
Mark-RS
Post by Mark-RS » Tue Jan 23, 2018 3:37 pm
Yeah I certainly think someone has had a poke around here before. There is a parrot thingy my bobby stuck to the dash which I am going to remove, maybe this is sliced in somewhere ?
Like I said, it all appears to power up fine. I can connect my phone to it but just no sound. I may have to start unpicking the blocks where the speaker wires "Appear" to be and join them up and see if I get sound...
Or I may just pay someone who know what they are doing to avoid me setting the car alight 2 weeks after getting it :D
Post by Shoppinit » Tue Jan 23, 2018 3:49 pm
I am always horrified at what people do to car electrics. Shat works seems to be the rule rather than the exception. Once I saw some MAF wiring stuck together with kitchen foil and chewing gum. :shock:
Users browsing this forum: Bing [Bot], philS2 and 118 guests
