Creaking Dash...
4.2 V8 32v FSI - 444 bhp
Sammyb349
Creaking Dash...
Post by Sammyb349 » Thu Jan 04, 2018 8:19 pm
Has anyone had the joys of the dash creaking and rattling. For me, it’s occuring in or around the MMI screen area. Is there any easy way to ‘tighten’ it up or is it a garage/warranty job?
Sam
Current:
- Audi B8 RS4 - Panther Black
Previous:
PSB1
Re: Creaking Dash...
Post by PSB1 » Thu Jan 04, 2018 8:43 pm
I have this. I've had it will all 6 of my B8s. The interior quality is <beep>. They may be able to make it go away partially, or temporarily. It will be back though. <beep>, low grade plastics.
'kin stonking V8 helps drown it out though. :rocker:
steve099
Post by steve099 » Sat Jan 06, 2018 9:33 am
I also have quite a few squeaks and rattles in mine, especially when i am in dynamic mode on lesser roads. Its driving me up the wall and it will be going to the dealer when I get back from holidays to try and fix the one in the back that sounds like a lose socket rolling around in the quarter panel.
2015 RS4 Avant - Mythos black
Sammyb349
Post by Sammyb349 » Sun Jan 07, 2018 12:03 pm
I also have that noise!! At first I thought I had left something in the boot, but no.
Mine is off the garage in 2 weeks - pls let me know how you get on!
Current:
Previous:
Surrey Sam
Post by Surrey Sam » Sun Jan 07, 2018 12:14 pm
Intresting, mine doesn't creak or squeak. But once in a blue moon I hear this almighty crack noise, like a large stone hitting the windscreen at speed. I just put it down to thermal expansion of some kind.
Rich1782
Post by Rich1782 » Sun Jan 07, 2018 12:39 pm
Sounds stupid but if you have tyres overinflated can cause extra rattles and creaks, or if your drc isn’t right as ride is harder!
Creaks behind mmi could be the triangle shaped mesh on top middle of dash. Mine was rattling so I used to bang it to get it to stop until I put my fist through it! Bought a new one (£24 not the £240 the tit at service originally quoted...) and seems to have stopped. Rattles from the back can be the plastic ‘spare wheel’ hub beneath the boot floor not tightened properly and sitting flush and the boot trim on the door where the open/close button is (give the trim a bang when open to see if it rattles). I had the sd card unit making an annoying creak for a while but that seems to have gone too, plus the piano black door trims make a sticky rattle at certain speeds like most new cars do it seems! It generally seems to be road and speed dependant as sometimes it’s completely silent!
Sammyb349
Post by Sammyb349 » Sun Jan 07, 2018 6:16 pm
Thanks Rich - i’ll get banging and see what is what
Current:
Previous:
PSB1
Post by PSB1 » Mon Jan 08, 2018 7:58 am
I have just given up on trying to fix it. I just drive the tits off it instead. Roof down yesterday, glorious.
N13LXC
Post by N13LXC » Mon Jan 08, 2018 1:26 pm
had it on both of mine (though the original sepang one was far worse than the noggy!) I stuck a tiny bit of folded paper under the MMI where the soft touch met the carbon fibre, that seemed to solve it...
Mrs Car: A220d AMG line
Brooner
Post by Brooner » Mon Jan 08, 2018 2:40 pm
I drive in dynamic setting 99% of the time the only issues i have is the boot cover rattling my project this year is yo sort that
steve099
Post by steve099 » Tue Jan 16, 2018 7:26 am
its looking like I have rear suspension issues with mine, so its going into the stealership tomorrow however its probably pointless as the previous owner installed kwv3's so I am going to assume they will tell me to go jump if the DRC setup is faulty even though its still under factory warranty.
I am thinking along the right lines and if so, what sort of pricing am i looking at to get it repaired should I be forced to pay it?
Surrey Sam
Post by Surrey Sam » Tue Jan 16, 2018 8:31 am
You won't have any DRC with KW's fitted.
steve099
Post by steve099 » Wed Jan 17, 2018 11:15 am
Audi refused to even look at it today, once they realised it had kw's fitted and an after market sub woofer installed in the boot.
awesome service for what was a $180k AUD car when new. NOT.
Sammyb349
Post by Sammyb349 » Wed Jan 17, 2018 8:14 pm
My rear rattle was the jack in the spare wheel chamber. The nut that screws into the top of the battery had come loose. Simple fix. The dash is going into the dealer to get looked at in February. Will report back
Current:
Previous:
Surrey Sam
Post by Surrey Sam » Wed Jan 17, 2018 9:04 pm
I don't see what your problem with Audi is?
You have a knocking suspension noise from your aftermarket suspension. Talk to the garage that fitted them or KW, don't try wasting Audis time with it.
