Battery replacement.
benh999
Post by benh999 » Tue Jan 16, 2018 8:49 pm
My RS has been sat since Oct and the battery is flat as a pancake..
Put her on charge however it doesn’t seem to be charging to full. My charger will charge up battery and then switch to maintenance mode and this is not happening so I’m assuming the battery is possibly on it’s way, so........
What batteries are proven to be good and well priced..
Links/thoughts?
Ben :-)
mavada
Re: Battery replacement.
Post by mavada » Tue Jan 16, 2018 8:55 pm
Battery
110Ah
Varta VA0 DE 000 915 105 AK
Dimensions: 394mm long, 175mm wide, 190mm high.👍
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Steveo
Post by Steveo » Tue Jan 16, 2018 9:12 pm
I replaced mine about a year ago. I had the Varta one but I couldn't get hold of another one at the time. So I bought a Bosch one instead. The two batteries are identical!
I'll try and get a picture of the Bosch one tomorrow if it stops raining for long enough
RS6 C5, MTM
Post by Shoppinit » Tue Jan 16, 2018 10:53 pm
Those big batteries can take a long time to charge. Varta FTW.
dch1n
Post by dch1n » Tue Jan 16, 2018 10:54 pm
Got mine from Tanya batteries for £125 last year.
610 200 Varta Silver Dynamic Car Battery 12V 110Ah 020 (Short Code: I1) (Varta DIN: 610 402 092 )
Does the job just fine.
Dan
https://www.tayna.co.uk/Varta-VW-1J0-91 ... P9383.html
Sent from my Pixel using Tapatalk
Ben_r1
Post by Ben_r1 » Wed Jan 17, 2018 8:52 am
I usually just use a Halfords battery, good savings with a trade card and 5 year warranty can’t go wrong 👍
Post by Shoppinit » Wed Jan 17, 2018 9:04 am
Good luck trying to use that warranty, though. They always wriggle out.
I've had unbranded, cheapo batteries that have lasted for 10+ years and I've had known brand batteries that have hari-kari'd after 4 years. Seems to be pot luck. Once the battery in my Golf 2 exploded and the acid stripped all the paint off the battery tray and engine bay around it. :rant: I think it was a Bosch.
benh999
Post by benh999 » Wed Jan 17, 2018 1:11 pm
How long ish?(from flat)
Post by Shoppinit » Wed Jan 17, 2018 2:05 pm
With a 110Ah battery and a feeble charger, could take as long as 3 days.
Post by Shoppinit » Wed Jan 17, 2018 2:06 pm
I recently charged some 180Ah marine batteries from flat and that took about 5 days.
Steveo
Post by Steveo » Wed Jan 17, 2018 2:11 pm
I had my Varta one on charge for over 36hrs on an old and fairly basic Halfords charger. But it has done the job fine. It'
RS6 C5, MTM
benh999
Post by benh999 » Wed Jan 17, 2018 3:33 pm
Aha.. I’ll keep charging then I’d say this had been on for 18rs. I just assumed it would have trickle charged by then?
Post by Shoppinit » Wed Jan 17, 2018 3:50 pm
Simplistically: Most domestic chargers are less than 4A max charging current. Also the current tapers off as the battery charges. So say on average 1.8A over the charging cycle. Assuming 70% charging efficiency to charge a 110Ah battery (assuming full capacity) then it'll take approximately 3.7 days. Maths, innit.
Ben_r1
Post by Ben_r1 » Thu Jan 18, 2018 1:47 pm
Swapped a few myself, never had that much f a problem. They email you the receipt now too.
benh999
Post by benh999 » Thu Jan 18, 2018 1:49 pm
She’s charged... green light for Maintenance mode, CheersShoppinit :-)
Users browsing this forum: Google Adsense [Bot], philS2 and 394 guests
