Starter motor / relay
5.0 V10 50v biturbo - 571 bhp
993turbo
Post by 993turbo » Sun Jan 07, 2018 8:48 pm
Hi there,
Where is the starter motor located?
Is there a starter rele', is so, where is it?
Cheers,
:audibash:
RS6 MTM C6 Avant (Daily Driver)
360 Modena (manual)
F430 Spider (F1)
+ 4 classic Porsches
douglas96
Re: Starter motor / relay
Post by douglas96 » Tue Jan 09, 2018 11:49 am
Hi,
Here is the procedure to remove/install the starter motor. It's attached to the gearbox so doesn't look like the easiest of things to get to. I'll have a look later on today where the starter relays are on the car.
Douglas
As pointed out by Jim, the procedure does actually state the engine and gearbox have to be removed.
Jim Haseltine
Post by Jim Haseltine » Tue Jan 09, 2018 12:51 pm
It says 'Engine/gearbox assembly removed'.
douglas96
Post by douglas96 » Tue Jan 09, 2018 1:31 pm
God so it does!! It's a bit early in the morning for me to be posting I think! :? Thanks!
Jim Haseltine
Post by Jim Haseltine » Tue Jan 09, 2018 5:20 pm
I've also had a quick look at things and doubt that you can get to the starter mounting bolts and cables with the downpipe and turbo in place. If I've got the time (and it's a bit warmer) at the weekend I'll see about taking a closer look.
993turbo
Post by 993turbo » Thu Jan 11, 2018 8:37 pm
So they built the car around the starter motor. :-/
Anything on the starter relay?
360 Modena (manual)
F430 Spider (F1)
douglas96
Post by douglas96 » Thu Jan 11, 2018 8:48 pm
Sorry, I completely forgot. I'll be on the computer shortly so should be able to post it in an hour or so!
douglas96
Post by douglas96 » Thu Jan 11, 2018 9:57 pm
Hi 993turbo,
Here are the fitting locations for the starter relays and also a current flow diagram should you need it (hopefully not though). Also I see your location is Marbella so I'm assuming that your car is a left hand drive as you can see from the pictures.
Hopefully this helps you.
Jim Haseltine
Post by Jim Haseltine » Fri Jan 12, 2018 9:21 am
Well, they've got previous for that sort of thing. The clutch master cylinder on RHD 80s, coupes & Ur quattros is almost impossible to get to - from what I remember, the dealer book time was 9 hours for R&R. I got it down to 6 the last time I did one with most of that time being spent kneeling outside the driver's door working in the footwell.
993turbo
Post by 993turbo » Mon Jan 15, 2018 8:07 pm
Cheers! Fixed. Starter relay.
360 Modena (manual)
F430 Spider (F1)
douglas96
Post by douglas96 » Mon Jan 15, 2018 8:17 pm
Great news! Glad you got that sorted. Which one was it, or did you just change the two of them?
993turbo
Post by 993turbo » Sun Jan 21, 2018 8:55 pm
The main one. Upper to the right. Its a standard rele’
360 Modena (manual)
F430 Spider (F1)
