vcds scan
rickster147
vcds scan
Post by rickster147 » Fri Jan 05, 2018 2:58 pm
anyone know what needs fixing fault code isAddress 01: Engine Labels:. 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0080
Revision: --H09--- Serial number: XXXXXXXXXXXXXX
Coding: 01040003180F0160
Shop #: WSC 00844 210 84027
VCID: 6390A7A47756AF3F273-8036
1 Fault Found:
008568 - Bank 1; System Too Rich off Idle
P2178 - 002 - - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 164587 km
Time Indication: 0
Freeze Frame:
RPM: 1633 /min
Load: 46.3 %
Speed: 62.0 km/h
Temperature: 71.0°C
Temperature: 8.0°C
Absolute Pres.: 970.0 mbar
Voltage: 13.208 V
Readiness: 0000 0000
the car seems hesitant sometimes when accellerating
i had the same for bank 2 aswell but that code hasnt come back as yet any help appricated
Rs4 b7 In avus silver with b14 Bilstein coilovers, centre resonator delete with x pipe and piggie cats gutted
Headlights detangoed trups led kit drl reverse and numberplate kit
Previous audi
rs6 c5 - mrc stage 2 remap-itg filters-forge dumpers-center decat with miltek kw coilovers- h and r
I call her the growler lol
jonytek
Re: vcds scan
Post by jonytek » Fri Jan 05, 2018 3:19 pm
I'm sure someone will correct me if I'm wrong but I think that this is common and nothing to be concerned about.
Don't suppose it's traction control kicking in when you're giving it a good old fashion thrashing is it?
BUILD THREAD
IG: @bad_rs_4
Stigaream
Re: vcds scan
Post by Stigaream » Fri Jan 05, 2018 3:22 pm
Italian tune
rickster147
Re: vcds scan
Post by rickster147 » Fri Jan 05, 2018 3:34 pm
No mate deffo not traction control I've read it could be spark plugs coil packs 02 sensors or maf sensor
Previous audi
Stigaream
Re: vcds scan
Post by Stigaream » Fri Jan 05, 2018 3:37 pm
Got the same.
Deleted codes then drove the car HARD.
Seems its ok now.
I will drive later today to check
RS4LAD
Re: vcds scan
Post by RS4LAD » Fri Jan 05, 2018 8:55 pm
A friend of mine had this numerous times and got very paranoid, changed all the sparks and coil packs and it hasn’t ever come back.
Users browsing this forum: Google Adsense [Bot] and 1818 guests
