Lingering Revs
2.7 V6 30v biturbo - 380 bhp
Bigfatbob
Lingering Revs
Post by Bigfatbob » Tue Nov 01, 2005 3:29 pm
Does anyone know why the revs on my cars "linger" when I accelerate. If accelerate quite hard to say 5-6k, the engine takes a long time to slow down making the gear change slow, otherwise it is very jerky.
What can I do to fix this?
Will
DaveP
RE: Lingering Revs
Post by DaveP » Tue Nov 01, 2005 3:54 pm
You can fit a lightweight flywheel...this should help...but there can be drawbacks depending on which type you fit (such as a slight rattle at low revs under load)
DaveP...
Audi Allroad - Daily slogger
S1 Exige - Track beast
derdle
RE: Lingering Revs
Post by derdle » Tue Nov 01, 2005 6:15 pm
Could this be a sign of an air leak ??? I know mine did this once and it had an air leak - a split hose which when replaced restored the rev behaviour to normal.
RS4 in the only colour to have - Misano Red | MRC Remap | RS6+ brakes | H&R and Custom Performance Parts suspension |
Huge Grin :biggrin3: If you dont "do it now" you never will.
Bigfatbob
Post by Bigfatbob » Tue Nov 01, 2005 7:02 pm
Was this discovered by a garage or youself and how did you identify the hose that was faulty?
derdle
Post by derdle » Wed Nov 02, 2005 10:03 am
It was discovered by Kim at QST doing a pressure test.
Bigfatbob
Re: RE: Lingering Revs
Post by Bigfatbob » Wed Nov 02, 2005 1:46 pm
derdle wrote:Could this be a sign of an air leak ??? I know mine did this once and it had an air leak - a split hose which when replaced restored the rev behaviour to normal.
Just a further question then. What is "normal" behaviour? should the revs rise and fall quickly or is there a certain amount of "lingering" as that is the nature of the engine.
derdle
RE: Re: RE: Lingering Revs
Post by derdle » Wed Nov 02, 2005 1:52 pm
Now you ask I can't quite put my finger on it...all I know is the car behaved (as I would call) normally after the split hose was replaced! I think I first noticed a problem when gear changes were not as nice as they used to be.
simple1
Post by simple1 » Wed Nov 02, 2005 9:35 pm
The idle speed is controlled by a valve, same one that controls idle speed when air con or lights are switched on........... the valve does have a habit of gettin blocked with burnt oil deposits, it could also be the result of an incorrectly set throttle switch........... not much help I know.......
Golich
Post by Golich » Fri Nov 04, 2005 3:08 pm
The RS4 should not do what your describing.
But if you were talking about a new style 1.6 A3 they are shocking. I swear they have set the ECU to increase the revs on pressing the clutch. This was ceratinly the case with the loaner I had over a year ago!
Bigfatbob
Post by Bigfatbob » Fri Nov 04, 2005 4:11 pm
Could the problem be ECU related? Is there much difference in revs "drop" between a standard and modified RS4?
A trip to AMD or QST might be on the cards to discuss options.
Golich
Post by Golich » Sun Nov 06, 2005 11:54 pm
Very unlikely its the ECU. No tuner would introduce this kind off response. Its more likely an air leak somewhere. That kind of problem can occur in any car.
911TT_STEVO
Post by 911TT_STEVO » Mon Nov 07, 2005 1:18 pm
This is why I recently made a post regarding my Porker having a boost leak!
I don't want to make you guys paranoid but it is always worth getting it checked, I was always 0.5 bar and when I had the ECU done it should have been double (still was 0.5) that's when I knew something was wrong! I have a meter in the car, so this gives me some indication. But if you have a boost leak you will lose a bit of power and also fuel consumption!
Bigfatbob
Post by Bigfatbob » Mon Nov 07, 2005 2:03 pm
How do you identify where the leak is? And are there particular areas I should be looking?
The garage will be doing this but if I can point them in the right direction it might be quicker and cheaper.
simple1
Re: RE: Re: RE: Lingering Revs
Post by simple1 » Mon Nov 07, 2005 5:37 pm
911TT_STEVO wrote:This is why I recently made a post regarding my Porker having a boost leak!
:lol: At 80 miles to a tank round Spa, maybe I have a boost leak :biggrin2: :biggrin3:
911TT_STEVO
Post by 911TT_STEVO » Mon Nov 07, 2005 6:06 pm
:shock: :lol: :lol: :lol: :lol: :lol: might well have after your foot wasn't lifted once! :lol: :lol: :lol: :lol: :lol: :lol:
