420mm discs
Tommcole
420mm discs
Post by Tommcole » Thu Dec 07, 2017 6:54 am
Hi Guys
Has anyone tried to fit 420mm discs on the front of a b7 rs4 ?
I currently run 20" wheels ..
Here is a pic of my car for the hell of it
TimberTech RS4
Re: 420mm discs
Post by TimberTech RS4 » Thu Dec 07, 2017 8:08 am
Have a look on insta for kimboyrs4 he’s fitted 410s
iconic78
Re: 420mm discs
Post by iconic78 » Thu Dec 07, 2017 8:35 am
He had to machine down the Caliper to get it to fit under the wheel. Also some wheels won’t allow the figment. Depends on the profile.
dhali
Re: 420mm discs
Post by dhali » Thu Dec 07, 2017 11:39 am
OT. Have you got laminex on your headlights ??
Softishman
Re: 420mm discs
Post by Softishman » Thu Dec 07, 2017 1:09 pm
Go big or go home!!! ;)
@softishman on IG
Check out my RS4 there!
irn_bru_ce
Re: 420mm discs
Post by irn_bru_ce » Thu Dec 07, 2017 6:25 pm
How much heavier are 420mm Vs OEM, can't imagine it does much for the handling
Current - 07 Avus Silver B7 RS4 Avant : Ceramics, Non Valved Non Res Milltek, K&N filter, SS+, adaptive xenons, black optics, KW3, 034 rear ARB, rear drop links & front adjustable top arms.
Past - 00 Saxo VTS : 266mm Mi16 calipers, Quaife ATB, 20mm torsions bars, 24mm ARB, Vibratechnics mounts
87 Vauxhall Belmont: 1.6L, 15" rockford fosgate subwoofer in 3 cuft sealed box, 5ch Rockford fosate amp, JBL components
Softishman
Re: 420mm discs
Post by Softishman » Thu Dec 07, 2017 7:51 pm
420 ceramics are lighter then oem 365 steel
@softishman on IG
iconic78
Re: 420mm discs
Post by iconic78 » Fri Dec 08, 2017 7:44 am
Here’s the thing, if your planning on running 420’s what are you doing to upgrade the master cylinder or brake booster?
If it’s just for looks then fine but you’ll never get the full potential of the disc as the cylinder can’t pump enough fluid effectively.
If it did you’d be over braking on the fronts.
Easiest way to see if they fit is to use a cardboard cutout and centre it on your hub.
Softishman
Re: 420mm discs
Post by Softishman » Fri Dec 08, 2017 11:05 am
It has nothing to do with the discs, is the area of the pistons on the caliper. Oem is 8-piston calipers. Brembo caliper for the 400mm and the 420mm is only 6-piston but a little bigger area so the brake pedal travel is about the same. If you choose the bigger Alcons calipers for the 420mm disc they are 8-piston and the pedal travel should be a little longer for the same braking power.
@softishman on IG
iconic78
Re: 420mm discs
Post by iconic78 » Fri Dec 08, 2017 4:46 pm
Softishman wrote:It has nothing to do with the discs, is the area of the pistons on the caliper. Oem is 8-piston calipers. Brembo caliper for the 400mm and the 420mm is only 6-piston but a little bigger area so the brake pedal travel is about the same. If you choose the bigger Alcons calipers for the 420mm disc they are 8-piston and the pedal travel should be a little longer for the same braking power.
I think you misunderstood me.
Softishman
Re: 420mm discs
Post by Softishman » Fri Dec 08, 2017 6:52 pm
I don’t think so.
@softishman on IG
Users browsing this forum: Zyox and 259 guests
