Engine light
Engine light
Engine light has popped up. Is there anyway of viewing the problem from the system without having to take it to Audi?
Sent from my SM-G955F using Tapatalk
Re: Engine light
Unless you have VCDS, no.
Re: Engine light
Or a bluetooth OBD dongle and an app on your phone. I believe ODBEleven and Carista both do this but I think both require the use of their own dongles and not the super cheap ones on ebay.
Re: Engine light
I did my stage one upgrade around 3 months ago. Engine light came on last week..
Is intermittent, comes on and off. Strangely, it seems to go off when I really push the car then back on when the car is being driven normal.
Weather has changed alot in the kat few weeks, it's become much cooler.
Re: Engine light
This is by far the best way as you can also see the logs or you can like mike said, use a obd scanner to get the fault code and go from there.doodlebug wrote:Unless you have VCDS, no.
Nick at elite in DIP2 has a Rosstech cable and also Autohaus has one.
Re: Engine light
Thanks. Had a bad experience with autohaus, another one of those Dubai companies that just isn't interested in taking my money. Tried to contact them a few time for different jobs and they never return calls, emails etc.. Even when chasing them.. Very strange.iconic78 wrote:This is by far the best way as you can also see the logs or you can like mike said, use a obd scanner to get the fault code and go from there.doodlebug wrote:Unless you have VCDS, no.
Probably a decent company but the current team is just very incompetent.
Re: Engine light
I can’t comment on there work as I’ve never had anything done there myself. I just know they have a cable. Are you on the Vag uae group?DXB_RS6 wrote:Thanks. Had a bad experience with autohaus, another one of those Dubai companies that just isn't interested in taking my money. Tried to contact them a few time for different jobs and they never return calls, emails etc.. Even when chasing them.. Very strange.iconic78 wrote:This is by far the best way as you can also see the logs or you can like mike said, use a obd scanner to get the fault code and go from there.doodlebug wrote:Unless you have VCDS, no.
Re: Engine light
I'm sure the actual work is decent once it manages to get inside but it's the front line service staff, sales team that are letting the business down.
No I'm not on that group, where is it?
Re: Engine light
Or search VW Audi club UAE
