Front & Rear discs and pads
At 50k I think the time has come to change discs and pads all round. Too date I’ve only changed the front pads once
Just had a quote off Audi Leicester of £1250 for the fronts and £997 for the rears.
Anybody recommend anywhere else or tell me if that’s a good deal.
Would consider doing it myself if I could get the rear auto handbrake turned off to do them, fronts are easy
- innercry666
Re: Front & Rear discs and pads
Just had a quote from Crewe Audi:
RRP on all the bits is £1826.46.Please see below for my prices-
Front pads - £318.00
Front discs - £660.00
Rear Pads - £66.00
Rear Discs - £576.00
Prices include free UK shipping with UPS.All items in stock ready to post.
Obviously doesn't include fitting but a good independant would see this right. Leicester Audi are notoriously expensive!
Rear Pads - £66.00
RS6 PE - Current
RS4 (B8.5) 2015 - Sold
A4 3.0 TDI Quattro BE Avant - Gone
Focus ST170 - Garaged
- innercry666
Tom Fox <T.Fox@creweaudi.co.uk>
RS6 PE - Current
Thanks, ill drop him a mail. Feel pretty comfortable doing the fronts and surely it cant be that hard to do the rears with the electronic brake
- Surrey Sam
Fronts are easy to do. I purchased a front pad set from Tom at Crewe Audi 6 months ago, price not too different then at £315. Audi recommend fitting a new pad retention kit as well.
Here's a how to guide on replacing rears on a RS5, this should be the same for us RS4 owners, but you'll need VCDS to retract the EPB.
http://audirevolution.net/forum/index.php?topic=2379.0
Maybe a stupid question, but Given you can actually park the car without engaging the electronic park brake, would I be able to swap out the rear disc and pads without the VCDS procedure.
- Surrey Sam
Don't think so, as the EPB only retracts part of the way back to help speed up the on/off process. Doing it via VCDS retracts it all the way back to reset for new pad/disc thickness.
- Surrey Sam
Looking around online, some people have removed the EPB motor from the calliper, got a T40 and then wound the EPB clockwise which allows for the piston to be compressed back. You could try that (at your own risk)?
Thanks, I watched a video of somebody doing this on you tube, hmmm not sure, think a friendly local garage who has VCDS would be a better option
- Surrey Sam
Again, looks easy enough and prefer it over the two wire & a 12v battery method. That way could certainly risk damaging the electric motors.
Roughly where are you located, perhaps there's a forum member with VCDS near you that can help? I'm in West Sussex and have VCDS, so can easily help.
Thanks Sam, im in warkswickshire
https://rover.ebay.com/rover/0/0/0?mpre ... 2794547909
Fantastic price!!
Fantastic price!!
Christ, audi dealership also
