Multi Function Display died..
5.0 V10 50v biturbo - 571 bhp
niall1
Post by niall1 » Mon Jun 19, 2017 1:41 pm
Hi all
The multi function display between my analogue clocks has died. It had been flashing on and off or slow to display on cold mornings but a few weeks ago it died altogether. I got an electrical burning smell at the time and my mechanic has had a look and confirmed that the circuit board has fried itself. Is this a common fault or have I just been unlucky? Audi want over a grand for a replacement unit plus labour and programming etc.. An auto electrician in Cork said he might be able to help but needs to know the make of the display (Bosh/VDO/etc). Anyone have any idea what make it is or were there different ones for the RS6?
Niall
Too many cars..
C_J
Re: Multi Function Display died..
Post by C_J » Mon Jun 19, 2017 4:20 pm
Bba reman repair these. It'll be 2 chips that fail, one transformer and one mosfet. Very common.
S4 b5 340bhp
Rs4 b5 507bhp
Rs6 c6 project 800bhp
S3 stock daily work hack
douglas96
Post by douglas96 » Mon Jun 19, 2017 9:23 pm
Hi Niall,
If you have VCDS it should be able to tell the manufacturer of the instrument cluster.
Click "select" on "select control module".
Then click "17-instruments"
It should be listed next to "component".
niall1
Post by niall1 » Wed Nov 15, 2017 5:49 pm
Hi guys, I sent the cluster away to be repaired locally and it was returned to me as apparently the board is fried.. What are my options as a new replacement unit from Audi Ireland is too expensive.
Too many cars..
Henry3467
Post by Henry3467 » Wed Nov 15, 2017 8:42 pm
Hi pal there’s one eBay U.K. at the moment and it’s reasonably priced let me know if your interested and I’ll see if I can find the item number
Henry3467
Post by Henry3467 » Wed Nov 15, 2017 8:44 pm
Hi there I’ve just checked buddy and there still for sale item number is 132352044423 hope that helps
Henry3467
Post by Henry3467 » Wed Nov 15, 2017 10:34 pm
Niall I’ve just pmd you buddy
niall1
Post by niall1 » Wed Nov 15, 2017 10:36 pm
Thanks a million. I've bagged that. Hopefully it does the trick! 👍
Too many cars..
Henry3467
Post by Henry3467 » Wed Nov 15, 2017 10:41 pm
Yes it should do buddy I’ve bought a few bits off the guy he’s been great what you’ll have to do is get the data transferred from the old clocks to these it’s just the memory in the chip on the clocks any dash correction place should be able to do it
Or you’ll have to get the clocks configured at the stealers
Anyways good luck
Cheers henry
Badassgermanlook
Post by Badassgermanlook » Wed Nov 15, 2017 11:22 pm
Try these guys, all you do is send them the cluster and they repair and return. They state the below.
Your instrument cluster will not lose any mileage or immobiliser data once repaired and you will not need to re-code the unit once you receive it back repaired from us. Just plug in and play.
http://www.clusterrepairsuk.co.uk/repai ... ir-service
Audi RS6 V10 Avant
moss
Post by moss » Wed Jan 17, 2018 12:52 am
hi, ive just picked up my rs6 and have exactly the sane issue with my display, can you give me any pointers on how to remove that centre part ? can you still drive the car with it away for repair
thanks
niall1
Post by niall1 » Wed Jan 17, 2018 8:24 am
It's an integral part of the unit containing the analogue clocks either side. PM sent
Too many cars..
Castleguy
Post by Castleguy » Mon Feb 19, 2018 9:41 pm
Well mine has started doing the same especially when it snows !! not gone but suppose it is on its way so any tips on removal so I can send it away appreciated - GRRRRRRR that and the boot all at once !!
Badassgermanlook
Post by Badassgermanlook » Mon Feb 19, 2018 10:57 pm
Mines been playing up since winger came. Hopefully the summer will rectify it until next winter! Lol
Audi RS6 V10 Avant
niall1
Post by niall1 » Tue Feb 20, 2018 7:26 am
That's how mine started, infrequently playing up until it eventually died..
Too many cars..
Users browsing this forum: Google Adsense [Bot] and 35 guests
