MikeFish's RS4 Saloon for sale
So, I've been talking about it for ages but now it has finally happened; my much loved RS4 is up for sale.
Much of the history of this car is recorded in my build thread; link in my signature. Unfortunately, due to Photoshop being a bunch or ***** most of the photos don't show up anymore, but I think if you click on them they might still work.
Even though I don't believe in it, I had it carbon cleaned by MRC. It recorded 438ps / 482NM, and it won't stay like this but it was literally driven from MRC to my house then to the car dealers so has only done 150 miles since being cleaned; just for you! Many cars being sold with carbon cleans carried out a year or 2 ago which is pretty much the same as never being done.
Here's the details:
The Spec
2007 (07 plate) first registered July 2007
Facelift version
Coming up to 73,000 miles
4 previous owners
Owned by me for over 7 years (since Aug 2010)
Phantom Black Pearl
Full Leather Buckets seats
Black headlining
Flat Bottomed Steering Wheel
Sports Suspension (modified, see below)
Originally alu optics from factory (now black optics, see below)
Auto opening boot lid
Auto headlights
Auto wipers
Auto dimming mirror
Adaptive bi-xenon headlights
Coming Home lights
Privacy glass
Carbon trim (currently removed, see below)
Heated front seats
Cruise Control
Dual Zone Climate Control
Mot until 07th June 2018
Tracker fitted and operational
All 3 original keys and key code
Audi RS4 Alcantara Manual & Service book wallet (original one also included)
No reported errors on VCDS
Servicing
04/04/08 7421m Stratford Audi
30/12/08 13474m Stratford Audi
07/05/09 21441m Stanstead Audi
02/11/10 26416m Camberley Audi
30/09/11 38369m Victoria Audi
16/11/12 50225m Victoria Audi
31/12/13 57779m Leicester Audi
30/12/14 64597m Leicester Audi
29/12/15 71416m Leicester Audi
31/12/16 72356m Leicester Audi
As you may have noticed I have used 3 different dealers for my servicing. I started servicing at Camberley but I then moved house and Victoria Audi was more convenient (close to my work). I eventually settled with Leicester Audi (my local dealer) as they had better customer service.
Mods
MRC stage 2 remap (Nov 2012)
Gutted pre-cats (MRC Nov 2012)
OEM exhaust modified by removing centre resonator
Exhaust valves disconnected & pipes blocked (by MRC)
Revolution Carbon Air intake with Pipercross dry filter
Cold air feed with larger than normal 102mm pipe. These cars normally have an 89mm CAF as that is similar to the size of the trumpet on OEM air box but with the open carbon intake the larger cold air feed makes a big difference with regards to reducing heat soak.
Secondary Air Injection System removed and mapped out by MRC
Carbon engine cover (RH side)
Matt aluminium rear bumper strip sprayed Phantom black
Front grille replaced for genuine Audi Black Optic version
Window trims sprayed in matt black
Wing mirrors sprayed matt titanium (L8AU)
2010+ LED RNSE fitted (latest firmware)
Audi Music Interface to allow USB drives to be used or the better ipod interface
KW adjustable spring kit (retains DRC)
034 Adjustable top arms (front) fitted June 2016. Allows front camber to be adjusted (not normally adjustable on the RS4)
Super Sports suspension (SS+) thicker rear anti-roll bar fitted
EBC Yellow brake pads fitted front and rear fitted for sale
HEL braided brake hoses (front and rear)
LED interior lights
LED tail lights. I have the original lights and can be supplied too
LED DRLs and sidelights
20” Audi RS5 rotors powder coated in gunmetal, only been driven from my house to the car showroom.
The original 19” alloys powder coated in anthracite with Goodyear Eagles F1s fitted with approx 2mm tread also available
Audi R8 oil cap
Audi R8 coolant cap (modified to face the right way)
Audi R8 power steering reservoir cap (modified to fit B7)
Smoked side repeaters
Seat backs & seat belt hoops sprayed in Audi Ibis White
Interior trim wrapped in white gloss
The original full set of carbon trims (in excellent condition) will also be supplied
Forge Oil Cooler & pipes
Fog light grilles were modified and sprayed Phantom Black but I have a removed these so you have a brand new set of unmodified ones fitted now
Triple heated windscreen washer jets (genuine Audi upgrade instead of twin jets)
Work done
Full Main Dealer Service History
On longlife service but serviced once a year now irrespective of service schedule in car (9 services at Audi to date, see above for details)
Last service December 31st Dec 2016
Full carbon clean carried out by MRC May 2017 at 72406m (approx 150 miles done on it since). Dyno graph included reading 438ps
New track rod ends fitted by MRC April 2017 72406m
New oil separator / breather cyclone and seal conditioner MRC April 2017 72406m (due to smoky exhaust)
As part of the above work it also had new oil and filter at the same time so effectively it was a service but I didn't get the service book stamped or clock reset to maintain the full Audi Service History
Had respray carried out to entire front end to get rid of stone chips by Reflex Auto Design (July 2016). Also both sides sprayed around the rear doors / wheel arches to tidy up chips / scratches
New front left driveshaft fitted June 2017. The old one didn't actually fail; it had a misplaced or damaged retaining clip which caused the drive shaft to slip out and damage the splines. I suspect the clip was not put back properly following the CV gaitor replacement
Oil Cooler & pipes changed for Forge Oil Cooler July 2014
New OEM carbon engine covers fitted to replace yellowing originals
New Coolant reservoir fitted (no fault, just for looks)
Both Clutch switches replaced (nothing wrong with old, just a precautionary measure)
New MAF fitted July 2017
New nearside Aux radiator fitted November 2012 (offside removed for Cold Air Feed)
New Audi windscreen fitted Nov 2014 (proper OEM Audi one)
3 shocks and pipes replaced for latest type in Autumn 2013. Only one had failed, the other 2 changed as a precaution.
All left hand CV gaitors replaced (front & rear, inner & outer); (rear nearside inner, front nearside inner 2014) the other 2 in June 2016)
New front suspension top arms fitted same time as lowered (and replaced again when 034 adjustable ones fitted June 2016)
New starter motor June 2016
New offside engine mount June 2016
All 3 Steering Rack bolts changed for new ones June 2016 as a precaution (common issue)
Spark plugs changed 31/12/13 at 57779m
Brake fluid changed by Audi at last service
Brand new lower trim for steering wheel to renew badge (to freshen up badge)(now scratched by wheel alignment Shop (grrrrrr!!!)
Brand new fog light grilles to replace modified ones
255/30/20 Goodyear Eagle F1s with 5mm tread left
New central vent (dash) replaced as paint had a flake missing (like that when I bought it)
New Tool Box and no missing tools
Boot lid struts replaced as it was a little slow to open
Recent Hunter 4 wheel alignment (all green), then aligned by MRC when they changed the track rod ends on April 2017
Replaced rubber petrol cap securing strap as it was starting to perish (also had new petrol cap fitted at the same time)
New tyre sealant in boot as the original one was about to expire
Pads were OK but I changed front and rear anyway ready for sale
Front discs changed on 03/07/12 at 46828m
Front disc thickness 33.4mm (range is 34-32mm so plenty of life left in them)
Rear discs changed at 65,000
Rear discs thickness 21.3mm (range is 22-20.4 so again plenty of life left)
The bad
I don’t know if the exhaust valves work. They previously worked when last used but as I have them disconnected they probably need a little help to free up if you want them working again
Slight smoke from exhaust when cold due to no precats and no secondary air injection. Not a fault. Well documented issue on RS246 forum.
Annoyingly, the bottom steering wheel cover has a scratch after replacing for a new one just for a new badge.
Exhaust flexis are damaged, common problem on the RS4, especially lowered ones. I asked MRC to check and replace if required recently when it was in for a health check and they didn't think there was any need to replace them.
Also included;
Carbon interior trim in excellent condition
Original rear lights in excellent condition
Original air box and filter, unknown if it still works or how new the filter is
Something like 5 sets various of logo'd car mats as well as the set in the car which includes a logo'd boot liner.
I have put the car up for 'sale or return' as I don't have the time to or inclination for test drives etc.
Autotrader advert with photos:
https://www.autotrader.co.uk/classified ... 0029870208
£17,985
Here's the details:
The Spec
Facelift version
4 previous owners
Phantom Black Pearl
Black headlining
Auto headlights
Auto wipers
Auto dimming mirror
Coming Home lights
Privacy glass
Heated front seats
Cruise Control
Servicing
Mods
LED interior lights
Audi R8 oil cap
Work done
The bad
Also included;
£17,985
Re: MikeFish's RS4 Saloon for sale
Possibly the most well known B7 on RS246
Someone's going to get a great car
GLWS Mike
P.S. Good ad!
GLWS Mike
P.S. Good ad!
2007 RS4 B7 Avant
- SimonS4MTM
- Top Gear
Looks amazing, and a great for sale add. Makes fab reading. Good luck with the sale.
- daytonamart
- 5th Gear
Epic ad Mike,
One of the best forum cars for sure, GLWS.
Gone B7 RS4 Sprint Blue Avant
Gone B7 A4 Reflex Silver
Wow Mike, end of an era for you in the B7 world.
Glws, shouldn't take long it's a top car
RS4.....another
Previous - all sorts
RS4.....another
Thanks guys.
- Surrey Sam
Goodluck Mike, it'll be a sad day when it finds a suitable new home.
Wow this must have taken a while to put down on "paper" great ad! Tasty mods! Lovely car! I suggest you hold interviews for potential buyers ha ha only for the worthy!! Like Ferrari who chose who to sell to lol! Good luck!
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Pistolpete2543
Very well sorted car, seems very reasonably priced too. GLWS Mike, but I hope you aren't going to leave the B7 section of the forum as you've been very helpful to many of us.
Nah not with commission by MRCPistolpete2543 wrote:Very well sorted car, seems very reasonably priced too. GLWS Mike, but I hope you aren't going to leave the B7 section of the forum as you've been very helpful to many of us.
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Audi Pardner
Wow, what a difference a well written ad makes. Reflects the care you've taken with the car Mike.
Sorry to see you leave the fold
; who's going to answer my dumb-ass questions now?
Bet you're gonna miss her!
That ad!
1.4 Fiesta (Silver)
2.8 VW Bora V6 4motion (Blue)
4.2 Audi RS4 B7 Avant (Black)
1.4 Fiesta (Silver)
Stunning car, good luck Mike.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
How do you like them apples?! Great car, shame it’s going, but will make someone very happy. Superb post, doubt it will hang about. Best of luck and look forward to more on the other cars
Great advert Mike. Good luck with the sale mate.
Users browsing this forum: No registered users and 27 guests
