Shift lights
Re: Shift lights
Post by MikeFish » Tue Sep 26, 2017 12:45 am
Not sure about HUD, but on the DIS it's not quite shift lights, it's a bar that changes colour as you approach and hit the red line. Nits urge everyone here is talking about the same thing. To get this shift bar you need to be on the lap timer screen and have the gear stick pushed to the left to the proper Manual setting and not just in Drive or Sport and manually changing with paddles or feat lever. Must have gear stick pushed to the left. Then floor it and see gear shift bar changing colour.
whiteq
Re: Shift lights
Post by whiteq » Tue Sep 26, 2017 6:43 am
I may check out Vagcom as mine doesn't come up in every driving scenario, it may be an Australian Delivery car code problem.
Northerner
Re: Shift lights
Post by Northerner » Tue Sep 26, 2017 12:47 pm
Tadass910 wrote:
Northerner wrote:
Tue Sep 19, 2017 6:40 pm
Worked it out on the way home. The shift lights only show up on the heads up display and not the dash.
You are wrong, they showed in both in hud as well in dash, you need to be in manual mode and use shift paddles
Not on my car...
Sent from my SM-G928F using Tapatalk
