The next step..Lowering a C6 RS please educate me on best option with DRC
5.0 V10 50v biturbo - 571 bhp
SteveG
Post by SteveG » Fri Aug 11, 2017 12:50 pm
Hi Guys,
As above, I want to lower the car a little and get some H&R ARB.
What is the best recommended option for lowering one of these a little whilst keeping ride comfort as current ?
Thanks for any help.
kent_andy
Re: The next step..Lowering a C6 RS please educate me on best option with DRC
Post by kent_andy » Fri Aug 11, 2017 12:56 pm
best option is set of springs. i looked at MTM ones but KW are essentially the same. you would then keep DRC and the ability to switch damper settings.
2017 911 991.2 Turbo S
2007 Audi A3 2.0T Quattro
SteveG
Post by SteveG » Fri Aug 11, 2017 2:33 pm
Hi Andy,
OK, I will look at the MTM springs. Any vendors on here ? MRC is other side of the M25 and booked up solid for a month :(
SteveG
Post by SteveG » Sat Aug 12, 2017 8:06 am
Do I need to find a fitter that will need to also reset/ correct DRC post spring fitment ?
rs6_sid
Post by rs6_sid » Sat Aug 12, 2017 10:00 am
nope as long as they don't loose any pressure or fluid from the drc system unless they have the specialist recharge kit
c6 rs6 avant- mrc stage 2 -current
bmw e61 m5 saloon
s3 8p stage 2
vw bora tdi hybrid turbo
IanH755
Post by IanH755 » Sat Aug 12, 2017 4:01 pm
You may have issues correcting the camber post lowering because, as far as I can tell, no-one sells a camber adjustable arm with enough adjustment for a lowered car. So you'll start to burn through the inner edge of the front tyres more quickly than before.
SteveG
Post by SteveG » Sat Aug 12, 2017 6:31 pm
Hmm, doesn't sound ideal. Thanks for pointing out Ian.
Steve
IanH755
Post by IanH755 » Sat Aug 12, 2017 7:12 pm
Don't get me wrong it's not like you'll go through a set in under 2k miles or similar but you will notice a tyre duration difference between lowered and stock.
Pgj0hns0n
Post by Pgj0hns0n » Sat Sep 09, 2017 6:34 am
With standard 20" rims, what are most people lowering their car by without any interference? I appreciate tyre choice but a general view would be appreciated!
Also, if you put 21" on, any view on best lowering springs - 20mm reduction?
Pj
A20LEE
Post by A20LEE » Sat Sep 09, 2017 11:57 am
I've lowered my as far as it will go on KW Platforms and its rubbed on the arch liners at the rear. Switched to Michelin PSS and now theres no rubbing. Previous tyres were PZero's
Pgj0hns0n
Post by Pgj0hns0n » Sat Sep 09, 2017 1:17 pm
Can i ask what you lowered your car by - 20mm around? Also, did you also add wheel spacers?
PJ
A20LEE
Post by A20LEE » Sat Sep 09, 2017 4:36 pm
45mm, the maximum the kit allows. No spacers.
Users browsing this forum: Google Adsense [Bot] and 136 guests
