RNS-E upgrade, bluetooth and media player
craigyb
Post by craigyb » Fri Oct 14, 2005 5:57 pm
Some pics of my upgraded Nav system, car was delivered with Sat Nav (CD based) TV and CD changer.
Now it has an RNS-E (DVD sat nav), TV, 400GB Media player, Phatnoise and an Audi OEM Telephone BT preperation.
Phone Dialer
Navigation
Radio Screen
craigyb
Post by craigyb » Fri Oct 14, 2005 6:00 pm
More pics....
Media player and phatnoise
Watching a Movie
craigyb
Post by craigyb » Fri Oct 14, 2005 6:07 pm
More Pics....
Dialled names in the DIS
Microphone in lighting dome
Phone book is read by RNS-E
craigyb
Post by craigyb » Fri Oct 14, 2005 6:09 pm
More Pics....
Remote Control for media player
The car itself...
Connecting a call
TWH
Post by TWH » Sat Oct 15, 2005 9:22 am
Looks sweet. Must have cost a fair bit if similar to upgrading on the rs4
2001 Avus Silver RS4, APRacing 6pots - Gone, but not forgotten :(
craigyb
Post by craigyb » Sun Oct 16, 2005 12:05 am
Actually not too much....
Around £2500 for the lot
Craig
TWH
Post by TWH » Sun Oct 16, 2005 10:05 am
That's pretty good then. Was it a pain to fit, or could you just swap the old unit straight out?
craigyb
Post by craigyb » Sun Oct 16, 2005 11:14 am
The Nav units I fit all the time, so for me it was pretty straight forward, about 2 hours work and a straight swap, some wiring changes etc.
The TV is upgraded as well to the latest revision tuner, that takes about 30 mins, but needs a new connector at the HU end.
Phatbox is a 30 minute job as it needs to be repositioned in the CD changer cradle for a good fit.
Telephone, around 3 hours work, running the mic cable up to the lighting dome is a pain, but the rest is fairly easy tapping into the HU woring harness.
The Media player was the biggest job as it required some wires to be run from the front to back for the remote control and switched live. Also the media tray in the boot needed some work to house the player.
Finally TV in motion, on the RS6 I used the spare roller blind switch, as I don't have one, as the TV in motion enable, mounted some relays under the dash to change the momentary swicth to a latching one, added illumination and used the relays to cut the speed pulse (GALA) wire.
So the only unsightly thing on my dash now is the origin B2.
Craig
DaveP
Post by DaveP » Sun Oct 16, 2005 7:46 pm
Looks good matey! :thumbs:
DaveP...
Audi Allroad - Daily slogger
S1 Exige - Track beast
shimmy
origin b2
Post by shimmy » Sun Oct 16, 2005 9:19 pm
how have you done the origin B2. If it is dash mounted have you hard wired it?
are there amy good ways to fit it without having it sitting on the top of the dash?
regards
shimmy
M3 CSL
ex RS6
ex E39 M5
ex Mini 1275GT
craigyb
Re: origin b2
Post by craigyb » Sun Oct 16, 2005 9:24 pm
shimmy wrote:how have you done the origin B2. If it is dash mounted have you hard wired it?
B2 is mounted on the dash to the right of the driver, hard wired with a GPS splitter to the Audi roof GPS receiver to give a better lock time etc.
Here's a pic of it, ignore the mic in front, that is now mounted in the roof as shown above.
HGH
RE: Re: origin b2
Post by HGH » Sun Oct 16, 2005 10:31 pm
Do you have done it yourself ?
When you did, do you have all the electric wiring
connections written down ?
DrB
RE: Re: origin b2
Post by DrB » Sun Oct 16, 2005 10:41 pm
I have my B2 in the same spot. I have a problem at the moment with electrical interference. It sporadically keeps alarming 'diffuser'. I have put an ferrous cuff over the power cord, but the problem seems to be getting worse. Have you had any false laser signals?
RS 6+
2001-2006 S4
2006-2012 RS6
2012-2016 ML350 CDI
2016-2018 RS6 PE
2018 - Tesla MS100D
craigyb
Post by craigyb » Sun Oct 16, 2005 10:55 pm
I did everything myself, I sort of install Nav systems in Audis as a part time ocupation. So I know what I'm doing to a reasonable degree.
When I install things, I look for clean solutions, that are practical and easy to use, I hate cluttered dashes with lots of cables and I like the OEM look.
As for the B2, I dont have the laser diffuser installed, I think I decided that, if it came on, I was nicked anyway.
Craig
shimmy
Re: origin b2
Post by shimmy » Sun Oct 16, 2005 10:55 pm
craigyb
i remmeber one of your posts showing the b2 above the parking sensor switch in the midle of the dash. was that your car and if so did you move it for a reason.
you should get the LE-30. some good reports i have read on M5board thatg they work a treat and do block the signal longg enough to slow down. Also can link the LE-30 and b2.
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
regards
shimmy
M3 CSL
ex RS6
ex E39 M5
ex Mini 1275GT
