Rs4 b7 wheel fitment thread
chriswhite1992
After searching i can believe no one has made a proper thread for wheel fitment on the rs4 so im going to make one!
Post up you pictures on here.
Wheels and Offset
Spacer Size
Tire Size and Make
Suspension Setup
Camber Settings
Toe Settings
Hopefully this will help people decide on what size wheels to buy
Just for people who don't know
Standard rs4 alloys are 19x9j et29
Wheels and Offset
Spacer Size
Tire Size and Make
Suspension Setup
Camber Settings
Toe Settings
Last edited by chriswhite1992 on Sun Feb 05, 2017 9:02 am, edited 1 time in total.
- MartayMcFly
- 5th Gear
Re: Rs4 b7 wheel fitment thread
Wheels and Offset - Audi Q7, 20x9J ET60
Spacer Size - 35mm pcd adapter
Tire Size and Make - 255/30R20 Michelin PSS
Suspension Setup - DRC with KW adjustable springs (approx 25mm lowered)
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2015 8V RS3 Stage 3 - sold
2017 Alfa Giulia Quadrifoglio
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
- MartayMcFly
- 5th Gear
Wheels and Offset - Audi RS5 Rotors, 20x9" ET26
Spacer Size - None
Tire Size and Make - 245/35R20 Toyo Proxes
Suspension Setup - KW V3 coilovers
Spacer Size - None
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
- MartayMcFly
- 5th Gear
Wheels and Offset - Rotiform SNA, 19x10J ET35
Spacer Size - None
Tire Size and Make - 265/30R19 Michelin PSS
Spacer Size - None
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
chriswhite1992
I think the rs5 rotors suit the b7 so well
suurenmoinen
Question: would 9.5x19 5x112 ET25 OZ Ultraleggeras HLT fit? (Michelin PSS 265/35/19)
suurenmoinen
According to this: http://www.willtheyfit.com/?aspect=35&a ... width2=265suurenmoinen wrote: ↑Mon Jul 24, 2017 6:50 pmQuestion: would 9.5x19 5x112 ET25 OZ Ultraleggeras HLT fit? (Michelin PSS 265/35/19)
"Compared to your existing wheel, this new wheel will have an inner rim which is 2.3mm closer to the suspension strut. The outer rim will poke out 10.4mm more than before."
Which should be fine...at the moment I am running 10x19 ET20 with minimum rubbing in the font under full suspension compression.
Any thoughts?
suurenmoinen
suurenmoinen wrote: ↑Wed Jul 26, 2017 11:45 amAccording to this: http://www.willtheyfit.com/?aspect=35&a ... width2=265suurenmoinen wrote: ↑Mon Jul 24, 2017 6:50 pmQuestion: would 9.5x19 5x112 ET25 OZ Ultraleggeras HLT fit? (Michelin PSS 265/35/19)
Any thoughts?
Does someone know if the Niche Form wheels in 20x10.5" ET27 will clear the brakes?
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 332 guests
