Minor 'lurching' on manual shifts
bn8959
Post by bn8959 » Thu Jul 27, 2017 10:39 pm
I have a 2016 non-PE FL C7, which I've had for a few months. No mods.
I've noticed it has a tendency to lurch forward when manually downshifting. For example when approaching a roundabout and downshifting to make use of engine breaking. It's as if the downshift throttle blip is happening before the clutch has fully disengaged, causing a lurch forward. It's only slight and dosent occur all the time. It's worse in S mode.
I find it quite unnerving, and defeats the engine breaking benefits as you speed up slightly with each downshift!
Is this normal?
2016 C7 RS6 - Panther Black
Previous:
2008 B7 RS4 Avant, Phantom Black
Markp
Re: Minor 'lurching' on manual shifts
Post by Markp » Fri Jul 28, 2017 8:20 am
Normal. It is a software issue I think - it is almost as if the car thinks you are downshifting to accelerate rather than brake, it gives a slight blip of throttle on the first downshift.
That said this is an auto so why downshift to engine brake? Never works well. Probably why the software isn't properly set up to do it. Just use the brake :)
bn8959
Post by bn8959 » Fri Jul 28, 2017 8:44 am
Humm. Guess so. Just seems satisfying to engine brake instead of wear down your brakes ;)
True it dosent work as well as a manual.
It should blip the throttle but just to match the rotation speeds either side of the clutch - supposed to make it a smooth transition.
I got 70k miles off my rear disks AND pads on my B7 RS4 :)
Previous:
Markp
Post by Markp » Fri Jul 28, 2017 8:45 pm
Aye but the tiniest blip on a 6 lights the fire in its belly :)
Users browsing this forum: No registered users and 175 guests
