Exhaust flap plug
IanH755
Re: Exhaust flap plug
Post by IanH755 » Wed Jul 26, 2017 5:34 pm
The valves are electrically powered to the "closed" position (unless dynamic is selected) so with the ignition off (no power) the valves will be kept open under spring power.
So as soon as you remove the plug from the valve (with the ignition on or off) the valves no longer have the power they need to stay closed, so they open and will remain open all the time. The Milltek plug does nothing for the valves, it just fools the ECU into thinking the valves are still connected.
HDPete
Post by HDPete » Wed Jul 26, 2017 5:49 pm
Thanks Ian
Post by MikeFish » Wed Jul 26, 2017 6:21 pm
hdpete wrote:
Wed Jul 26, 2017 4:50 pm
I've fitted my valve delete modules - nice and easy to do. Cable tied one side and tucked up the other side.
However, I'm quite underwhelmed by the difference. Is there a particular sequence to connect them - i.e. ignition on, in dynamic mode etc, or just disconnect and plug in module with ignition off (as I did)?
Have a look at your valves. Are they open or closed?
HDPete
Post by HDPete » Wed Jul 26, 2017 8:12 pm
Didn't realise they'd be visible - I'll take a look up the chuff in the morning.
IanH755
Post by IanH755 » Wed Jul 26, 2017 8:48 pm
They look like this (flap on the outer pipe)
Which is a bit of a disappointment that they're not part of the oval like the C5/6 but probably makes it cheaper/easier to make instead.
gsc
Post by gsc » Thu Jul 27, 2017 8:57 am
Whilst you can see them if you look closely at least the back boxes and tailpipes are black. It's the one disappointing thing about aftermarket exhausts in that boxes and pipes are silver and they are hugely obvious.
Users browsing this forum: No registered users and 60 guests
