Bolts anyone??
Re: Bolts anyone??
Post by Shoppinit » Mon Jul 24, 2017 7:52 pm
They don't need to bear load. Only centre the wheel. Once the bolts are tight the load is borne by the contact between the hub flange and the wheel.
Although I would argue that plastic is a bad idea because you should torque the bolts up with the wheel on the ground.
Ajc
Re: Bolts anyone??
Post by Ajc » Tue Jul 25, 2017 9:18 am
Oh I totally agree with you that they are a bad idea as they are easily lost when tyres are changed and you don't know about it until you remove the wheel weeks even months later when it's too late too go back and argue about it . (Not that I hold any bitterness).
Though I didn't exprerence any ill effect from not having one . Other than it being a total biatch to line the wheel up .
So yes they do a great job of aligning the wheel .
I would however argue that it's better too tighten a wheel unweighted as it's free to align its self without fighting the weight of the vehicle.
Cheers Al
Re: Bolts anyone??
Post by Shoppinit » Tue Jul 25, 2017 9:27 am
Agree, but it's not practical for most people to torque up a wheel in the air.
Ajc
Re: Bolts anyone??
Post by Ajc » Tue Jul 25, 2017 10:05 am
That's why every man needs an apprentice, they cone in very handy for standing on brake pedals ,Making coffee, sweeping floors and pretty much anything else I can't be arsed doing .
Cheers Al
Re: Bolts anyone??
Post by Shoppinit » Tue Jul 25, 2017 10:22 am
Sounds like my wife.
Re: Bolts anyone??
Post by bam_bam » Tue Jul 25, 2017 10:24 am
So you've gotta marry them before they'll sweep a floor?
Re: Bolts anyone??
Post by Shoppinit » Tue Jul 25, 2017 10:26 am
Depends how wisely you choose. Might not work on yours.
Daveperc
Re: Bolts anyone??
Post by Daveperc » Thu Jul 27, 2017 12:21 pm
Never thought this topic would get so interesting!!
I ordered 8 35mm bolts from the supplier link below. Only thir warehouse (aka ECP) managed to ship 8 SETS of bolts including lockable ones!! No wonder the package seemed so heavy on arrival. :cry:
Hopefully the right bolts will be here tomorrow.
Dave
RS2
Re: Bolts anyone??
Post by RS2 » Fri Jul 28, 2017 10:37 am
Shoppinit wrote:
Mon Jul 24, 2017 12:33 pm
RS2 wrote:
Mon Jul 24, 2017 11:29 am
Sorry to point this out... but... (this is my understanding of it... that's all ;) )
The wheels are centered on the wheel bolt head and recess design in the wheels rather than on the spigot itself.
The spigot is simply there to allow you to line up the wheel bolts easily.
Once you have torqued the wheel bolts up fully, the centering spigot performs no function whatsoever.
I strongly dispute this.
Personal experience has also shown me that the spigot is vital in centering.
While I agree that it helps... Vital is not the way that I would put it... otherwise OEM manufacturers wouldn't have done this.
These are from my 1990 T3 van. There are other vehicles that came without spigot centering and there is usually a mm or so clearance around the spigot. As you've pointed out, once the bolts/nuts are tight the spigot is redundant.
MG
Re: Bolts anyone??
Post by Shoppinit » Fri Jul 28, 2017 10:44 am
Maybe with the conical bolts the centering is better without a spigot to ensure alignment. Or maybe any application that can use steel wheels doesn't need good centering.
Either way, on the RS6 with OE alloys the spigot is vital for correct wheel centering.
Daveperc
Re: Bolts anyone??
Post by Daveperc » Mon Jul 31, 2017 12:30 pm
OK - I'll let you know how I get on with the 5mm spacers rather than hub-centric ones.
For those following the thread with intent interest the bolts finally arrived today - and the ECP part no is 983 77 5101 (that's each bolt).
Dave
Mɐʇʇ
Re: Bolts anyone??
Post by Mɐʇʇ » Mon Jul 31, 2017 7:09 pm
It's horses for courses, innit. Vital in some applications, less so in others. :)
Daveperc
Re: Bolts anyone??
Post by Daveperc » Tue Aug 01, 2017 6:59 pm
OK - the saga continues!!
Went to fit the rear (5mm) spacers and the longer bolts this pm..... and the bolts are too long!
There is something behind the bub which the bolts go into that partially obstructs the hole, and means the bolts have to be exactly the right length! :oops:
So, now my options are to either try and find some 32mm bolts, or to go for 8mm hubcentric spacers (all round)... Doh!! :bash:
Dave
Re: Bolts anyone??
Post by Shoppinit » Tue Aug 01, 2017 7:20 pm
:dung: You might as well just get 10mm spacers all round. They look perfect on the RS6.
/8 will be ok, too. But 10 FTW.
Mɐʇʇ
Re: Bolts anyone??
Post by Mɐʇʇ » Tue Aug 01, 2017 8:12 pm
10 FTW. :)
Users browsing this forum: Steve2003rs6 and 154 guests
