Gearbox ECU Problem
RS6Rottweiler
Re: Gearbox ECU Problem
Yes TCU, I have heard it called both so was unsure which was correct but it is the Gearbox TCU
RS6Rottweiler
That's a good idea, will ask Star Performance if they know someone who might do that?
If it's a new one the question then is do you risk buying second hand from eBay at the current prices of circa £500 minimum or buy a new one but none in U.K. so do Bosch have any available in Germany, any thoughts?
They used to be quite cheap, but I guess rarity makes them more expensive now. Have you searched for the part number on ebay.de?
I would be very curious to know if a regular A6 TCU could be flashed with the RS6 program. I suspect that technically it's possible, but AFAIK no-ones ever tried it.
There's this one:
http://www.ebay.de/itm/Steuergerat-Tipt ... 2459888920
Not cheap at 400 euros, but looks like that's the going price.
Did you look into this?mavada wrote: ↑Wed Jun 28, 2017 7:17 pmIts gearbox TCU...
Ive send mine to Viper Tuning some years ago, great service, Isle of Man.
http://vipertuning.com
RS6Rottweiler
Hi I'm nightshift at the moment so will try tonight, really appreciate your help, thank you
I'm the other side of the FR bridge, with a TCU that's not being used at the moment.
Is the car drivable?
Recycling dinosaurs for fun
^Top man.
Sweegie, did you ever get anywhere looking into reverse engineering the TCU?
Nah, once I got the MTM solution for the gearbox, I lost interest and started hacking Kawasaki bikes
To make real progress with it, you would need to run some kind of eeprom emulator with code tracing in the TCU, & that's beyond my toolset.
Been scanning through this post and I had a similar situation. Worked from cheapest parts upwards, kidding myself it wasnt the ecu. It was evidendednt it had been opened before so I wouldn't bet on a recon job. Fortunately a breaking Rs6 post came up, took the plunge and hey presto it was the TCU. Before I got there I tried reactance in the loom, replacing box loom, checking valves. if it looks like a turd and smells like a turn then......
It's bam??
Users browsing this forum: Majestic-12 [Bot] and 97 guests
