Clicking front right on braking/set off....at my wits end!
Re: Clicking front right on braking/set off....at my wits end!
Post by Shoppinit » Tue Jul 04, 2017 9:34 pm
Got a part number?
Piggy22
Post by Piggy22 » Tue Jul 04, 2017 9:37 pm
Got a part number?
616440405 £81.24 inc vat
Post by Shoppinit » Tue Jul 04, 2017 9:43 pm
Thanks. :thumbs:
Nobby
Post by Nobby » Wed Jul 05, 2017 11:10 am
Glad you got it sorted. Mine started a creak a few weeks ago and couldn't seem to get to the bottom of it. Only happened when heavy braking or turning slowly on full lock on both flat or bumpy surfaces.
Was nearly at the point of buying new CV joints and just happened to check the subframe bolts - none were massively loose, but I could get a quarter turn on a couple before they felt tight tight. Nipped them upto spec (110Nm + 90deg and they all seem fine). I think they are torque to yield stretch bolts so replaced with new ones and jobs a good 'un.
Daytona RS6 Avant
srichards
Post by srichards » Wed Jul 05, 2017 2:50 pm
Mine has just started creaking and squeaking. I did notice it seemed to happen just after going over a particularly vile bit of bumpy and potholed road. There were vibrations coming through the floor around the accelerator pedal.
I will check out the sub frame bolts. I'm surprised the car is still in one piece as all the roads locally are wretched.
fukinavit
Post by fukinavit » Wed Jul 05, 2017 6:35 pm
Piggy22 wrote:
Tue Jul 04, 2017 9:30 pm
Update:
I disconnected the anti roll bar and went for a drive, noise still there
I then took the rear lower arm completely off again and inspected it......it was in bits. Replaced with a lemforder item and now all is fine
so the arm you changed originally was a dud?
:assflash:
Piggy22
Post by Piggy22 » Fri Jul 07, 2017 8:29 pm
Update:
Yes the original arm was 1/3 of the price. I skimped, I learned :bash:
Users browsing this forum: Majestic-12 [Bot] and 146 guests
