Squeaking brakes
bedlamater
Squeaking brakes
Anyone else had this? Been doing it since about 2k miles and on 6k now? So can't be bothered to book it in for an inspection at Audi...
Re: Squeaking brakes
I have squeaking brakes at about 3mph when just about to stop - drives me nuts!! its due a service in 3kmiles so will get it looked at then. Had a similar issue on my 2015 RRS, they replaced the pads, no questions asked at 12kmiles
2018 Brabus G63 Widestar
2015 RS6 - with Added Milltek
2015 RRS - utter sh1te
2010 X5 4.0D M Sport
2009 R8 V10 Manual
2004 Lambo Gallarado Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
1990 Dimma Cosworth H20 COS
2003 996 DMS Turbo
multiple 205's Dimmas
2009 R8 V10 Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
2003 996 DMS Turbo
Seems to be brought up quite a lot on here! Occasionally notice it but i'm used to much noiser pads from track day and race cars so never bothered me - i woulodn't consider it a 'problem' as such.
Bear in mind it is colder now, so you may notice more until they're up to a decent temperature. Otherwise i think you have to accept you need to get Audi to look at it.
Current Fleet:
2016 Audi RS6 Performance
2015 Porsche 991 GT3
2015 Porsche 991 Carrera 4 Cab
2012 Porsche Cayenne Diesel
2010 Land Rover Defender 5.0 V8
On my rs4 b8 doing it more in this cold weather this week
rs4 b8 Suzuka, grey 14
I had it but it's now gone. Audi said its the consistency of material in the pad that's changed and they could not do anything with it
previous: RS2, RS4 2.7, RS4 4.2.
Current: S8 PLUS
Current: S8 PLUS
Had it with my ceramics, to be honest it was very close to me rejecting the car. Bit of "spirited" driving soon bedded them in. Good as new now.
It appears to be an issue with all performance Audi's :-/ mine do it on my R8, Audi are currently looking into it. But I think they'll just say it's a characteristic of the car.
My discs and pads were replaced 4k miles ago and the squeaking has returned.....from around 12mph on very gentle braking to a stop. Its going in for the exhaust valves on the 12th so will get them to look at the brakes once its in.
2009 R8 V10 Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
2003 996 DMS Turbo
2009 R8 V10 Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
2003 996 DMS Turbo
My S6 is in for squeaking brakes currently - just had a call to say that they are going to clean up the discs and pads to see if that fixes it ... 65% wear on the pads though, so inevitably they are going to say replace discs and pads if it carries on.
After a long battle with this on my C7 RS6, Audi have replaced the discs - I had to replace the pads as they were 70% worn. The discs are a different part number to the originals, the RS team said that the discs had been overheated......
Let's see if this works.
Mines started now....2k in and squeaking at low speeds. Is it worth taking it in.....or is the consensus that its going to be a waste of time?
Current:
2024 R8 - Daytona Grey
2023 Mercedes G63 AMG
2022 SQ5 - Grey
Most recent Audi
2020 RS6 Vorsprung - Sebring Black
2017 RS6 Performance - Ascari Blue
2022 SQ5 - Grey
Most recent Audi
Very common most of this is caused by not using the brakes hard enough
My 13 plate RS4 has 26k on original steel disks 2nd set of pads I occasionally get a squeal a low speeds but only after a long motorway run or a lot of stop start driving
This is solved by taking the car on a quite road a stamping hard on the brakes several time with out locking up the brakes to clean the pad material build up that causes the squeal
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
I've only had my C7 for a couple of months and they were squealing when i got it - they aren't now though! Maybe I use them more heavily than the previous owner?! 17k miles (I've done 2k of that).
2016 C7 RS6 - Panther Black
Previous:
2008 B7 RS4 Avant, Phantom Black
Previous:
Squeaking sound on ceramics are normal I suppose
I disagree. My ceramics never squeaked.Tadass910 wrote:Squeaking sound on ceramics are normal I suppose
Users browsing this forum: Google Adsense [Bot] and 100 guests
